0014257 | ParaView | (No Category) | public | 2013-08-29 13:41 | 2015-01-11 08:23 | ||||
Reporter | David C. Lonie | ||||||||
Assigned To | David C. Lonie | ||||||||
Target Version | Fixed in Version | 4.1 | |||||||
Summary | 0014257: Clean up GL2PS export dialog. | ||||||||
Description | Hide advanced options and make text-as-path default for PDF. | ||||||||
Project | TBD | ||||||||
Topic Name | 14257-gl2ps-dialog | ||||||||
Type | usability | ||||||||
(0031508) David C. Lonie (developer) 2013-08-29 16:22 |
Marked several options as advanced, and added GUI elements to hide/display them. To test: 1) Create a scene 2) Select File >> Export Scene 3) Export as .ps, .eps, .svg, or .pdf 4) After entering the filename, the configuration dialog appears. Toggle the gear to display/hide options. |
(0031515) Utkarsh Ayachit (administrator) 2013-09-03 11:11 |
SUMMARY --------------------------------------------- Topics merged into master: 14245_fix_default_values 14253_fix_translucent_slices 14257-gl2ps-dialog fix_edit_control_points (VTK) fix_plot3d_issue fix_vtk_mpi_change |
(0031598) Alan Scott (manager) 2013-09-18 13:25 |
Very nice testing instructions. Tested Linux, master, local server. |
2013-08-29 13:41 | David C. Lonie | New Issue | |
2013-08-29 13:41 | David C. Lonie | Assigned To | => David C. Lonie |
2013-08-29 16:22 | David C. Lonie | Topic Name | => 14257-gl2ps-dialog |
2013-08-29 16:22 | David C. Lonie | Note Added: 0031508 | |
2013-08-29 16:22 | David C. Lonie | Status | backlog => gatekeeper review |
2013-08-29 16:22 | David C. Lonie | Fixed in Version | => git-next |
2013-08-29 16:22 | David C. Lonie | Resolution | open => fixed |
2013-09-03 11:10 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2013-09-03 11:11 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2013-09-03 11:11 | Utkarsh Ayachit | Note Added: 0031515 | |
2013-09-18 13:25 | Alan Scott | Note Added: 0031598 | |
2013-09-18 13:25 | Alan Scott | Status | customer review => closed |
2013-11-01 13:18 | Utkarsh Ayachit | Fixed in Version | git-master => 4.1 |
2015-01-11 08:23 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master ff6333b1 |
2015-01-11 08:23 | David C. Lonie | Source_changeset_attached | => ParaView master a1e7e327 |
