0014259 | ParaView | (No Category) | public | 2013-09-04 10:11 | 2016-08-12 09:59 | ||||
Reporter | Mattijs | ||||||||
Priority | low | Severity | minor | Reproducibility | have not tried | ||||
Summary | 0014259: add region field to WaveFront obj reader (like stl reader) | ||||||||
Description | The stl reader automatically creates a field with the solid of the triangles. It would be great if similar handling could be added to WaveFront .obj files (using the 'g' group command) Attached a simple cube with every face in a separate group. | ||||||||
Project | TBD | ||||||||
Type | feature | ||||||||
Attached Files | cube.obj [^] (394 bytes) 2013-09-04 10:11 | ||||||||
(0038441) Kitware Robot (administrator) 2016-08-12 09:59 |
2013-09-04 10:11 | Mattijs | New Issue | |
2013-09-04 10:11 | Mattijs | File Added: cube.obj | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038441 | |
