0014281ParaView(No Category)public2013-09-17 12:382016-05-17 15:56
ReporterJeff Mauldin
Assigned ToAlan Scott
PriorityhighSeverityminorReproducibilityhave not tried
StatusclosedResolutionfixed
PlatformOSOS Version
Product Version4.0
Summary0014281: Turn off (optionallly) tick mark number labels on each axis on cube axes
DescriptionSometimes, particularly when you have a data volume which is narrow in one of the three x/y/z dimensions, the tick mark labels on the short axis(es) lie on top of each other, and the result is a detraction from the image. It should be possible to optionally turn off the tic mark labels on each axis, similar to how you can now turn on and off the tick marks and minor tick marks on each axis.
Also handy would be an intelligent mode where the number of tick labels reduced to avoid overwrite, and went invisible altogether when the axis took a sufficiently small angle of the view.
TagsNo tags attached.
ProjectCatalyst
Topic Name
Typefeature
 Relationships
  Notes
(0035972)
Alan Scott (manager)
2016-05-17 15:56
Cube axes is gone. Told Jeff about new Axes Grid. He will write up a new bug if necessary.
 Issue History
2013-09-17 12:38 Jeff Mauldin New Issue
2016-05-17 15:56 Alan Scott Note Added: 0035972
2016-05-17 15:56 Alan Scott Status backlog => closed
2016-05-17 15:56 Alan Scott Assigned To => Alan Scott
2016-05-17 15:56 Alan Scott Resolution open => fixed
