0014296 | ParaView | (No Category) | public | 2013-09-24 19:16 | 2016-08-12 09:59 | ||||
Summary | 0014296: CAM raw reader is HORRIBLE in parallel | ||||||||
Description | The CAM raw reader is horrible in parallel. It is horrible from a memory perspective as well as a performance perspective. My test is as follows: * Read famip5_ne240b.cam.h3.2001-09-09-03600.nc. This is a parallel reader. * Enable opacity mapping for surfaces. (I don't think this is the issue). * Plane (offset left side of screen). Texture map. Clip. * Plane (offset right side of screen). Texture map. Clip. Running remote server, performance is as follows: * 1 cores - 14 seconds final render - 1.58 GB/core * 2 cores - ?? seconds final render - 1.62 GB/core * 4 cores - ?? seconds final render - 1.24 GB/core * 8 cores - 26 seconds final render - 1.04 GB/core (8.45 total) So, 8 cores runs about half the speed of 1 core, and takes around 6 times as much memory. Ouch!! Please don't work on this until it has been discussed at a bi-weekly meeting, or you talk to Utkarsh or me. I have a few more observations, will include them in and additional post. | ||||||||
Project | Sandia | ||||||||
Type | performance | ||||||||
Attached Files | camReader8processes.jpg [^] (114,677 bytes) 2013-09-25 17:19
(0031619) Alan Scott (manager) 2013-09-24 19:17 |
Changing to high priority, since this basically makes this a serial reader, and the CAM reader is important. |
(0031624) Alan Scott (manager) 2013-09-25 16:57 |
Also, this reader does seem to be spreading the file across the map. Attached is a screenshot that shows this. |
(0031626) Alan Scott (manager) 2013-09-25 21:54 |
One place taking a lot of time is here: vtkKdTree::DoMedianFind, FP=7fff9a263660 vtkKdTree::DivideRegion, FP=7fff9a263780 vtkKdTree::DivideRegion, FP=7fff9a263890 vtkKdTree::DivideRegion, FP=7fff9a2639a0 vtkKdTree::DivideRegion, FP=7fff9a263ab0 vtkKdTree::DivideRegion, FP=7fff9a263bc0 vtkKdTree::DivideRegion, FP=7fff9a263cd0 vtkKdTree::DivideRegion, FP=7fff9a263de0 vtkKdTree::DivideRegion, FP=7fff9a263ef0 vtkKdTree::DivideRegion, FP=7fff9a264000 vtkKdTree::DivideRegion, FP=7fff9a264110 vtkKdTree::DivideRegion, FP=7fff9a264220 vtkKdTree::DivideRegion, FP=7fff9a264330 vtkKdTree::DivideRegion, FP=7fff9a264440 vtkKdTree::BuildLocatorFromPoints, FP=7fff9a264890 vtkMergeCells::MapPointsToIdsUsingLocator, FP=7fff9a264be0 vtkMergeCells::MergeDataSet, FP=7fff9a264e70 vtkDistributedDataFilter::MergeGrids, FP=7fff9a264fb0 vtkDistributedDataFilter::ExchangeMergeSubGridsFast, FP=7fff9a265250 vtkDistributedDataFilter::ExchangeMergeSubGrids, FP=7fff9a2652f0 vtkDistributedDataFilter::MPIRedistribute, FP=7fff9a2653b0 vtkDistributedDataFilter::RedistributeDataSet, FP=7fff9a265410 vtkDistributedDataFilter::RequestDataInternal, FP=7fff9a2657b0 vtkDistributedDataFilter::RequestData, FP=7fff9a265ce0 vtkDataObjectAlgorithm::ProcessRequest, FP=7fff9a265da0 |
(0038447) Kitware Robot (administrator) 2016-08-12 09:59 |
2013-09-24 19:16 | Alan Scott | New Issue | |
2013-09-24 19:17 | Alan Scott | Note Added: 0031619 | |
2013-09-24 19:17 | Alan Scott | Priority | normal => high |
2013-09-25 16:57 | Alan Scott | Note Added: 0031624 | |
2013-09-25 17:19 | Alan Scott | File Added: camReader8processes.jpg | |
2013-09-25 21:54 | Alan Scott | Note Added: 0031626 | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038447 | |
