0014318 | ParaView | (No Category) | public | 2013-10-05 21:18 | 2016-08-12 09:59 | ||||
Reporter | George Zagaris | ||||||||
Summary | 0014318: "Zoom to Box" does not behave properly | ||||||||
Description | The attached video recording was sent to me by the customer who was experiencing problems with the "Zoom to Box" functionality. I was able to reproduce this with the latest master (095ac28). Here are the steps to reproduce: (1) Open the attached GenericIO particle data (2) Select the x,y,z variables for each respective axis (3) Try to zoom in any of the halos (particle clusters) The customer had also multi-core enabled, likely with 2-4 processes. | ||||||||
Project | TBD | ||||||||
Attached Files | ZoomInBug.mov [^] (4,000,950 bytes) 2013-10-05 21:18 m000n.499.bighaloparticles [^] (557,560 bytes) 2013-10-05 21:19 | ||||||||
(0031680) George Zagaris (developer) 2013-10-05 21:22 |
I also tried this with multi-core disabled and was able to reliably reproduce the odd behavior. |
(0038450) Kitware Robot (administrator) 2016-08-12 09:59 |
2013-10-05 21:18 | George Zagaris | New Issue | |
2013-10-05 21:18 | George Zagaris | File Added: ZoomInBug.mov | |
2013-10-05 21:19 | George Zagaris | File Added: m000n.499.bighaloparticles | |
2013-10-05 21:22 | George Zagaris | Note Added: 0031680 | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038450 | |
