0014322 | ParaView | (No Category) | public | 2013-10-09 08:22 | 2013-11-20 08:56 | ||||
Reporter | Alejandro Ribes | ||||||||
Product Version | 4.0 | ||||||||
Target Version | Fixed in Version | 4.1 | |||||||
Summary | 0014322: client/server communication makes kernel's TCP buffer overflow | ||||||||
Description | Steps to reproduce: 1. Launch pvserver in mutli-client mode 2. Launch paraview client to connect to the above paraview -url=cs://localhost:11111 3. Launch the attached script (shrink-sphere.py), either with "pvpython" (in which case the Ctrl-C is not caught properly) or with python (and the correct PYTHONPATH) directly. 4. Inspecting the network status with: netstat --inet -np shows that the Python client script has its TCP buffer growing and growing (column "Recv-Q"). This ultimately crashes. It seems that the client is not trying to read everything the server sends. This is not a timing issue: increasing the "sleep" delay in the script to 1 sec shows the same behavior. This is only with scripting: the configuration with only pvserver and paraview-client doesn't exhibit the behavior. The behavior is seen with both the binary version (Linux 64 bits) and with a self-recompiled version (Linux 64 bits) of ParaView 4.0.1. -------- THE SCRIPT: # Supposing the pvserver is already started on 'localhost' from paraview import simple as spl from time import sleep # Connect to the pvserver spl.Connect('localhost') # Create a sphere and apply the Shrink filter to it: ss = spl.Sphere(Radius=2, ThetaResolution=32) shr = spl.Shrink(Input=ss) spl.Show(shr) spl.SetDisplayProperties(Representation = "Wireframe") #shr.SetPropertyWithName("ShrinkFactor", 0.9) # Loop on the shrink factor up and down for a while: shr.ShrinkFactor = 0.5 step = 0.1 try: while True: if shr.ShrinkFactor >= 1.0: step = -0.1 if shr.ShrinkFactor <= 0.0: step = +0.1 shr.ShrinkFactor += step sleep(0.1) pass except KeyboardInterrupt: print "Ctrl-C received" try: while True: pass except KeyboardInterrupt: print "Ctrl-C again! This time bye bye." spl.Disconnect() | ||||||||
Project | ParaViS | ||||||||
(0031705) Utkarsh Ayachit (administrator) 2013-10-21 07:57 |
Alejandro, When using pvpython with a multi-client pvserver, the Python code must manually call API to handle server-side events received from pvserver (which happens i multi-client mode). The Python Qt GUI takes care of that, and hence you don't see that happening when you use the Qt GUI. To process the events one should do the following: from paraview import collaboration ... # then periodically call: collaboration.processServerEvents() |
(0031721) Utkarsh Ayachit (administrator) 2013-10-24 08:37 |
SUMMARY --------------------------------------------- Topics merged into master: 14186_fix_point_sprite_issues 14263_fix_python_in_installs 14336_fix_examples 14337_delete_pipeline_error 14338_fix_build_issues 14339_fix_elevation_filter 14343_fix_tile_display_hang add-visitbridge-private-linking (VTK) hardware-selector-pv-bug pvweb-virtualgl-doc smaller-catalyst-editions sqplugin-topo-mapper-gui (VTK) update_vtk_master |
(0031868) Alejandro Ribes (manager) 2013-11-20 08:13 |
Hi Utkarsh, Your proposed solution was tested (by the CEA) and we are satisfy. Cheers, Alejandro. |
2013-10-09 08:22 | Alejandro Ribes | New Issue | |
2013-10-09 08:22 | Alejandro Ribes | Assigned To | => Utkarsh Ayachit |
2013-10-21 07:57 | Utkarsh Ayachit | Note Added: 0031705 | |
2013-10-22 08:55 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2013-10-22 08:55 | Utkarsh Ayachit | Resolution | open => no change required |
2013-10-24 08:37 | Utkarsh Ayachit | Fixed in Version | => git-master |
2013-10-24 08:37 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2013-10-24 08:37 | Utkarsh Ayachit | Note Added: 0031721 | |
2013-11-01 13:17 | Utkarsh Ayachit | Fixed in Version | git-master => 4.1 |
2013-11-20 08:13 | Alejandro Ribes | Note Added: 0031868 | |
2013-11-20 08:56 | Utkarsh Ayachit | Status | customer review => closed |
