0014349 | ParaView | (No Category) | public | 2013-10-22 13:53 | 2016-08-12 09:59 | ||||
Reporter | Christophe Trophime | ||||||||
Product Version | 4.0 | ||||||||
Summary | 0014349: paraview 4.0 FTBS with USE_EXTERNAL_VTK defined | ||||||||
Description | I'm trying to update paraview package in debian using vtk 6.0 packages. The patch provided by http://www.vtk.org/Bug/view.php?id=14157 [^] is not enough to get paraview build with USE_EXTERNAL_VTK defined The following files from VTK 6.0.0 should be also be installed: Build/lib/vtk-6.0/Modules/*-Headers.cmake usr/lib/vtk-6.0/Modules/ CMake/vtkTesting*.cmake usr/lib/vtk-6.0/ Build/ThirdParty/ftgl/vtkftglConfig.h usr/include/vtk-6.0/ ThirdParty/ftgl/src/FTGL.h usr/include/vtk-6.0/ Common/DataModel/vtkMarchingCubesCases.h usr/include/vtk-6.0/ Common/Core/vtkPointAccumulator.hxx usr/include/vtk-6.0/ Filters/Statistics/vtkStatisticsAlgorithmPrivate.h usr/include/vtk-6.0/ ThirdParty/netcdf/vtk_netcdf.h usr/include/vtk-6.0/ ThirdParty/netcdf/vtk_netcdfcpp.h usr/include/vtk-6.0/ usr/include/vtk-6.0/vtkTesting*.h IO/Import/vtk3DS.h usr/include/vtk-6.0/ I also make some change to vtkWrapperJava.cmake and vtk_netcdfcpp.h: # Modify vtkWrapJava.cmake to properly upload JavaDependencies.cmake.in from $VTK_DIR perl -pi -e "s|{dir}/JavaDependencies.cmake.in\"|{VTK_DIR}/JavaDependencies.cmake.in\"|" debian/libvtk-java/usr/lib/vtk-6.0/vtkWrapJava.cmake # Correct headers for paraview perl -pi -e "s|cxx|include|g" debian/libvtk6-dev/usr/include/vtk-6.0/vtk_netcdfcpp.h However this is not enough to get paraview to compile. There is some trouble with ParaViewConfig.cmake.in where VTKConfig.cmake is loaded only from the VTK directory shipped with paraview source tarball... This leads to some error when building : [ 53%] Generating CoProcessing/Adaptors/cthadaptor.done /usr/bin/ctest --build-and-test /tmp/buildd/paraview-4.0.1/CoProcessing/Adaptors/CTHAdaptor /tmp/buildd/paraview-4.0.1/obj-x86_64-linux-gnu/CoProcessing/Adaptors/CTHAdaptor --build-nocl ean --build-two-config --build-project CTHAdaptor --build-generator Unix\ Makefiles --build-makeprogram /usr/bin/make --build-options -DParaView_DIR:PATH=/tmp/buildd/paraview-4.0.1/obj- x86_64-linux-gnu -DCMAKE_BUILD_TYPE:STRING=RELEASE -DCMAKE_C_COMPILER:FILEPATH=/usr/bin/cc -DCMAKE_C_FLAGS:STRING=-g\ -O2\ -fstack-protector\ --param=ssp-buffer-size=4\ -Wformat\ -Werro r=format-security\ -D_FORTIFY_SOURCE=2\ -DCMAKE_CXX_COMPILER:FILEPATH=/usr/bin/c++ -DCMAKE_CXX_FLAGS:STRING=-g\ -O2\ -fstack-protector\ --param=ssp-buffer-size=4\ -Wformat\ -Werror=for mat-security\ -D_FORTIFY_SOURCE=2\ -DCMAKE_LIBRARY_OUTPUT_DIRECTORY:PATH=/tmp/buildd/paraview-4.0.1/obj-x86_64-linux-gnu/lib -DCMAKE_RUNTIME_OUTPUT_DIRECTORY:PATH=/tmp/buildd/paraview- 4.0.1/obj-x86_64-linux-gnu/bin Internal cmake changing into directory: /tmp/buildd/paraview-4.0.1/obj-x86_64-linux-gnu/CoProcessing/Adaptors/CTHAdaptor Error: cmake execution failed CMake Error at /tmp/buildd/paraview-4.0.1/obj-x86_64-linux-gnu/ParaViewConfig.cmake:54 (include): include could not find load file: /tmp/buildd/paraview-4.0.1/obj-x86_64-linux-gnu/VTK/VTKConfig.cmake Call Stack (most recent call first): CMakeLists.txt:4 (find_package) CMake Warning (dev) at /tmp/buildd/paraview-4.0.1/CMake/UseParaView.cmake:13 (include): include() given empty file name (ignored). Call Stack (most recent call first): CMakeLists.txt:5 (include) This warning is for project developers. Use -Wno-dev to suppress it. CMake Error at /tmp/buildd/paraview-4.0.1/CMake/ParaViewMacros.cmake:398 (include): include could not find load file: vtkForwardingExecutable Call Stack (most recent call first): /tmp/buildd/paraview-4.0.1/CMake/UseParaView.cmake:42 (include) CMakeLists.txt:5 (include) CMake Error at /tmp/buildd/paraview-4.0.1/CMake/ParaViewMacros.cmake:398 (include): include could not find load file: vtkForwardingExecutable Call Stack (most recent call first): /tmp/buildd/paraview-4.0.1/CMake/ParaViewPlugins.cmake:1 (include) /tmp/buildd/paraview-4.0.1/CMake/UseParaView.cmake:43 (include) CMakeLists.txt:5 (include) CMake Error at /tmp/buildd/paraview-4.0.1/CMake/ParaViewBranding.cmake:89 (include): include could not find load file: vtkForwardingExecutable Call Stack (most recent call first): /tmp/buildd/paraview-4.0.1/CMake/UseParaView.cmake:44 (include) CMakeLists.txt:5 (include) Configuring Configuring incomplete, errors occurred! make[2]: *** [CoProcessing/Adaptors/cthadaptor.done] Error 1 make[2]: Leaving directory `/tmp/buildd/paraview-4.0.1/obj-x86_64-linux-gnu' make[1]: *** [CMakeFiles/CTHAdaptor.dir/all] Error 2 make[1]: Leaving directory `/tmp/buildd/paraview-4.0.1/obj-x86_64-linux-gnu' make: *** [all] Error 2 | ||||||||
Project | TBD | ||||||||
Type | crash | ||||||||
(0031875) Utkarsh Ayachit (administrator) 2013-11-26 13:33 |
USE_EXTERNAL_VTK is not yet supported. We have made small steps towards it, but it's no where complete and not ready for prime time. |
(0032461) efferre79 (reporter) 2014-03-08 18:57 |
some patches in the issue 0014157 |
(0038451) Kitware Robot (administrator) 2016-08-12 09:59 |
2013-10-22 13:53 | Christophe Trophime | New Issue | |
2013-11-26 13:33 | Utkarsh Ayachit | Note Added: 0031875 | |
2014-03-08 18:57 | efferre79 | Note Added: 0032461 | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038451 | |
