0014377 | ParaView | (No Category) | public | 2013-10-31 12:51 | 2015-01-02 10:43 | ||||
Target Version | Fixed in Version | 4.3 | |||||||
Summary | 0014377: Chart selections are *not* cleared when global selection changes | ||||||||
Description | + Create Wavelet, Apply + Create Plot Over Line, Apply + Switch active view to 3D view and show the plot over line in 3D view too. Uncheck "Show Line" to hide the 3D widget and better see the probed line. + Select points in line chart view. You'll see that they get selected in the 3D view appropriately. + Now in the 3D view, using "Select Points On" select points on the probed line and you'll see the line chart updates as well. So far so good. + Switch the representation type for the "Wavelet" to Wireframe and then select a cell on the Wavelet. The 3D view shows the cell selected and clears the selection on the probed line, however the chart view still show the selected points. That's a bug. | ||||||||
Project | Sandia | ||||||||
(0033957) Utkarsh Ayachit (administrator) 2014-12-14 12:23 |
This now works as expected. The chart selection mechanisms were upgraded for 4.2 which seems to have addressed this problem too. |
(0033972) Alan Scott (manager) 2014-12-15 20:12 |
Tested master, Linux, remote server. |
2013-10-31 12:51 | Utkarsh Ayachit | New Issue | |
2014-12-14 12:23 | Utkarsh Ayachit | Note Added: 0033957 | |
2014-12-14 12:23 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2014-12-14 12:23 | Utkarsh Ayachit | Fixed in Version | => git-master |
2014-12-14 12:23 | Utkarsh Ayachit | Resolution | open => no change required |
2014-12-14 12:23 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2014-12-14 12:23 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-12-15 20:12 | Alan Scott | Note Added: 0033972 | |
2014-12-15 20:12 | Alan Scott | Status | customer review => closed |
2015-01-02 10:43 | Utkarsh Ayachit | Fixed in Version | git-master => 4.3 |
