0014391 | ParaView | (No Category) | public | 2013-11-04 08:44 | 2016-08-12 09:59 | ||||
Reporter | Dominik Szczerba | ||||||||
Product Version | 4.0 | ||||||||
Summary | 0014391: Errors in cutting or clipping 2nd order unstructured grid | ||||||||
Description | Cutting or clipping does not work properly for unstructured grid containing 2nd order prisms, hexahedrons and pyramids (there are missing face elements). Grid containing only 2nd order tets and mesh containing all element types but 1st order does not result in the same problem. Attached are mesh3.vtu, which is 1st order mixed mesh behaving correctly, and mesh6.vtu, 2nd order mesh with mixed elements, resulting in cutting problems. | ||||||||
Project | TBD | ||||||||
Attached Files | TestMeshes.zip [^] (736,254 bytes) 2013-11-04 08:44 | ||||||||
(0031876) Utkarsh Ayachit (administrator) 2013-11-26 13:43 |
I believe this is fixed in 4.1. Can you give the latest 4.1.0-RC1 a try? Thanks |
(0031890) Utkarsh Ayachit (administrator) 2013-12-04 11:56 |
Topics merged into master: 14295_search_text 14342-integrate-empty-servers (VTK) 14350-opacity-interpolate-scalars 14424_fix_copy_paste 14428_expand_valid_range export-tensor-glyph fix-streaming-behavior fix_SLAC_tools_segfault improve-selection-inspector make-sciberquest-module pv-collaboration-fix (VTK) pvweb-doc-update pvweb-fix-start-test-names pvweb-group-pattern-option (VTK) pvweb-integrate-test-packages-alternate (VTK) pvweb-session-manager-url-update pvwev-select-box-for-viewport-selection sqtk-cmake-warnings (VTK) update_vtk_master |
(0031905) Dominik Szczerba (reporter) 2013-12-05 08:11 |
Cutting seems now to work correctly, but (at least) cell data after cutting is damaged. |
(0031906) Dominik Szczerba (reporter) 2013-12-05 08:19 |
(0038458) Kitware Robot (administrator) 2016-08-12 09:59 |
2013-11-04 08:44 | Dominik Szczerba | New Issue | |
2013-11-04 08:44 | Dominik Szczerba | File Added: TestMeshes.zip | |
2013-11-26 13:43 | Utkarsh Ayachit | Note Added: 0031876 | |
2013-11-26 13:43 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2013-11-26 13:43 | Utkarsh Ayachit | Fixed in Version | => 4.1 |
2013-11-26 13:43 | Utkarsh Ayachit | Resolution | open => no change required |
2013-11-26 13:43 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2013-12-04 11:55 | Utkarsh Ayachit | Fixed in Version | 4.1 => git-next |
2013-12-04 11:56 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2013-12-04 11:56 | Utkarsh Ayachit | Note Added: 0031890 | |
2013-12-05 08:11 | Dominik Szczerba | Note Added: 0031905 | |
2013-12-05 08:11 | Dominik Szczerba | Status | customer review => backlog |
2013-12-05 08:11 | Dominik Szczerba | Resolution | no change required => reopened |
2013-12-05 08:19 | Dominik Szczerba | Note Added: 0031906 | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038458 | |
2016-08-12 09:59 | Kitware Robot | Fixed in Version | git-next => |
2016-08-12 09:59 | Kitware Robot | Resolution | reopened => moved |
