0014402 | ParaView | (No Category) | public | 2013-11-12 19:02 | 2016-04-15 22:24 | ||||
Priority | urgent | Severity | minor | Reproducibility | have not tried | ||||
Target Version | 5.0.1 | Fixed in Version | 5.0.1 | ||||||
Summary | 0014402: Save As Macro broken on Mac | ||||||||
Description | The super-awesome feature "Save As Macro" is not working correctly on Mac. I can replicate it reliably with the following steps. 1. Delete the ~/.config/ParaView directory. 2. Start ParaView 3. Tools -> Start Trace 4. Tools -> Stop Trace 5. (In the text edit) File -> Save As Macro Notice in the browser dialog, it is pointing to some directory that is not the appropriate ~/.config/ParaView/Macros. Thus, when you save the file, it does not appear as a macro. Oddly, if you go to the main ParaView app, select Macros -> Add new macro... then cancel and try the Save As Macro feature, it starts to work. It would be pretty great if this worked for the SC tutorial. | ||||||||
Project | Sandia | ||||||||
Topic Name | 14402_fix_save_macro | ||||||||
(0031855) Utkarsh Ayachit (administrator) 2013-11-14 17:15 |
commit 1e1b6e69da9fbee7e18ff3e859d8d303f8e7f655 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Thu Nov 14 16:33:21 2013 -0500 BUG 0014402: Fixed Mac issue by using pqFileDialog. Addresses bug by using pqFileDialog instead of QFileDialog. Change-Id: Ifc40be10399a44183d23ec4bd3782d03828f5752 |
(0031856) Utkarsh Ayachit (administrator) 2013-11-14 17:16 edited on: 2013-11-14 17:17 |
Merge topic '14402_fix_save_macro' 1e1b6e6 BUG 0014402: Fixed Mac issue by using pqFileDialog. Pushing upstream master To git@paraview.org:ParaView.git Deleting fully merged topic '14402_fix_save_macro' (1e1b6e6) from stage. |
(0033231) Ken Moreland (manager) 2014-08-18 11:22 |
There still seems to be some slight issues. If I follow the directions in the descriptions exactly, I get a browser dialog pointing to the right directory, but then if type in a filename and hit OK I get the following error: Cannot write file /Users/kmorel/.config/ParaView/Macros/test.py: No such file or directory. The issue seems to fix itself well enough so I don't think this is a huge issue. If I just hit "Save As Macro" again and try to save the file again, this time it works. Perhaps there is a minor problem in when the "mkdir" command is used. |
(0035769) Utkarsh Ayachit (administrator) 2016-02-23 10:54 |
MR: https://gitlab.kitware.com/paraview/paraview/merge_requests/653 [^] |
(0035795) Utkarsh Ayachit (administrator) 2016-02-25 09:44 |
It was indeed mkdir issue. Swicthed to use mkpath which creates all needed dirs. |
(0035894) Alan Scott (manager) 2016-04-15 22:24 |
Tested by user, and tested by me on 5.0.1. Mac, local server. |
2013-11-12 19:02 | Ken Moreland | New Issue | |
2013-11-14 17:16 | Utkarsh Ayachit | Note Added: 0031855 | |
2013-11-14 17:16 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2013-11-14 17:16 | Utkarsh Ayachit | Fixed in Version | => git-master |
2013-11-14 17:16 | Utkarsh Ayachit | Resolution | open => fixed |
2013-11-14 17:16 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2013-11-14 17:16 | Utkarsh Ayachit | Topic Name | => 14402_fix_save_macro |
2013-11-14 17:16 | Utkarsh Ayachit | Note Added: 0031856 | |
2013-11-14 17:16 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2013-11-14 17:17 | Utkarsh Ayachit | Note Edited: 0031856 | |
2014-01-11 08:39 | Utkarsh Ayachit | Fixed in Version | git-master => 4.1 |
2014-08-18 11:22 | Ken Moreland | Note Added: 0033231 | |
2014-08-18 11:22 | Ken Moreland | Status | customer review => todo |
2015-01-11 08:21 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 4af67def |
2015-01-11 08:21 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 1e1b6e69 |
2016-02-23 10:25 | Utkarsh Ayachit | Fixed in Version | 4.1 => |
2016-02-23 10:25 | Utkarsh Ayachit | Target Version | => 5.0.1 |
2016-02-23 10:54 | Utkarsh Ayachit | Note Added: 0035769 | |
2016-02-23 10:54 | Utkarsh Ayachit | Status | todo => gatekeeper review |
2016-02-23 10:54 | Utkarsh Ayachit | Fixed in Version | => 5.0.1 |
2016-02-25 09:44 | Utkarsh Ayachit | Note Added: 0035795 | |
2016-02-25 09:44 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2016-04-15 22:24 | Alan Scott | Note Added: 0035894 | |
2016-04-15 22:24 | Alan Scott | Status | customer review => closed |
