0014451 | ParaView | (No Category) | public | 2013-12-09 11:54 | 2015-01-11 08:21 | ||||
Target Version | Fixed in Version | 4.1 | |||||||
Summary | 0014451: Connect-ID is not working as expected. | ||||||||
Description | Start pvserver as follows: > pvserver --connect-id=12 Start ParaView as follows: > paraview --connect-id=13 and then connect to the server. The connection will happily happen! That's wrong. | ||||||||
Project | Sandia | ||||||||
Topic Name | 14451_fix_connect_id | ||||||||
(0031919) Utkarsh Ayachit (administrator) 2013-12-10 10:14 |
commit 01ad769ffbc957eb82ba961a8614ae7ebceb163f Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Tue Dec 10 10:10:13 2013 -0500 BUG 0014451: Restore connect-id authentication for client-server. Restoring logic to validate connect id when setting up client-server connections. The connect-id is now included in the handshake message which is used to validate the version compatibility. Also fixed assertion failure in pqCommandLineOptionsBehavior when a url was specified on command line, but the server rejected the connection due to mismatched handshake. Change-Id: I752d4237e15533e13db8ba12788dd966ef9b26d3 |
(0031935) Utkarsh Ayachit (administrator) 2013-12-15 12:14 |
Topics merged into master: 14240_mac_endianness 14451_fix_connect_id 14452_fix_go_to_last 14454_test_build_examples_against_pv_install PythonView add-pvweb-doc cosmo-fixes fix-histogram fix-python-module-install-dir fix-sciberquest-install fix_python_module_rules implement_new_fragment_analysis test_build_examples_against_pv_install unified-bindings2 |
(0031991) Alan Scott (manager) 2013-12-17 17:41 |
Tested Linux, master. Nice simple test. |
2013-12-09 11:54 | Utkarsh Ayachit | New Issue | |
2013-12-10 10:14 | Utkarsh Ayachit | Topic Name | => 14451_fix_connect_id |
2013-12-10 10:14 | Utkarsh Ayachit | Note Added: 0031919 | |
2013-12-10 10:14 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2013-12-10 10:14 | Utkarsh Ayachit | Fixed in Version | => git-next |
2013-12-10 10:14 | Utkarsh Ayachit | Resolution | open => fixed |
2013-12-10 10:14 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2013-12-15 12:14 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2013-12-15 12:14 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2013-12-15 12:14 | Utkarsh Ayachit | Note Added: 0031935 | |
2013-12-17 17:41 | Alan Scott | Note Added: 0031991 | |
2013-12-17 17:41 | Alan Scott | Status | customer review => closed |
2014-01-11 08:39 | Utkarsh Ayachit | Fixed in Version | git-master => 4.1 |
2015-01-11 08:21 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 25176459 |
2015-01-11 08:21 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master c4322d43 |
