0014506 | ParaView | (No Category) | public | 2014-01-10 06:34 | 2016-08-12 09:59 | ||||
Reporter | Mattijs | ||||||||
Product Version | 4.0 | ||||||||
Summary | 0014506: pick center does not select point on object | ||||||||
Description | (testing version 4.1rc2) Pick Center on a simple object (seen from e.g. z axis) sets x and y correctly but z is not on the object. Happens both in perspective and parallel projection. The z seems to be random and can actually happen to be outside the clipping plane. | ||||||||
Project | Sandia | ||||||||
Attached Files | cavity_0.vtk [^] (54,131 bytes) 2014-01-10 09:23 | ||||||||
(0032167) Mattijs (reporter) 2014-01-10 09:23 |
Some more info - I get the same behaviour in 4.0.1. - attached the vtk file (unstructured grid) that gives the problem - I do not get it if e.g. I generate a box (sources->Box) with same bounds - it does work correctly if I rotate the object to a very oblique angle |
(0032168) Mattijs (reporter) 2014-01-10 09:27 |
it also works if I first do a Filter->Extract surface |
(0036079) Alan Scott (manager) 2016-06-16 19:06 |
I found this in end to end testing a few minutes ago. Affects my users, thus moving to Sandia project. |
(0038489) Kitware Robot (administrator) 2016-08-12 09:59 |
2014-01-10 06:34 | Mattijs | New Issue | |
2014-01-10 09:23 | Mattijs | Note Added: 0032167 | |
2014-01-10 09:23 | Mattijs | File Added: cavity_0.vtk | |
2014-01-10 09:27 | Mattijs | Note Added: 0032168 | |
2016-06-16 19:06 | Alan Scott | Project | TBD => Sandia |
2016-06-16 19:06 | Alan Scott | Note Added: 0036079 | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038489 | |
