0014534 | ParaView | (No Category) | public | 2014-01-22 11:46 | 2016-08-12 09:59 | ||||
Reporter | Dan Lipsa | ||||||||
Summary | 0014534: Setting View (3D View) / Camera Parallel Projection is not pushed onto the UNDO stack | ||||||||
Description | Toggle advance properties Open View (3D View) properties panel Check Camera Parallel Projection The Undo button stays grayed. | ||||||||
Project | TBD | ||||||||
(0038499) Kitware Robot (administrator) 2016-08-12 09:59 |
2014-01-22 11:46 | Dan Lipsa | New Issue | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038499 | |
