0014536 | ParaView | (No Category) | public | 2014-01-22 11:54 | 2016-08-12 09:59 | ||||
Reporter | Dan Lipsa | ||||||||
Summary | 0014536: Recording a test for setting a background image does not work. | ||||||||
Description | Record a test: paraview -dr Tools / Record Test... Choose the file where to save the test Set Background type to 'Image' Choose 'Load...' In the file dialog choose ParaView/Data/NE2_ps_bath.png Press 'Stop recording' Press 'Disconnect' Play the test: Tools / Play Test... Choose the test file you just saved. You'll get the following error: Couldn't find object "pqClientMainWindow/propertiesDock/propertiesPanel/scrollArea/qt_scrollarea_viewport/scrollAreaWidgetContents/ViewFrame/ProxyPanel/BackgroundEditor/stackedWidget/page_1/Color/0QColorDialog0" Found up to "pqClientMainWindow/propertiesDock/propertiesPanel/scrollArea/qt_scrollarea_viewport/scrollAreaWidgetContents/ViewFrame/ProxyPanel/BackgroundEditor/stackedWidget/page_1/Color" | ||||||||
Project | TBD | ||||||||
(0032229) Dan Lipsa (developer) 2014-01-29 09:33 |
A workaround is to save this event before accessing the dialog. <pqevent object="pqClientMainWindow/propertiesDock/propertiesPanel/scrollArea/qt_scrollarea_viewport/scrollAreaWidgetContents/ViewFrame/ProxyPanel/BackgroundEditor/stackedWidget/page_1/Color" command="activate" arguments="" /> |
(0038500) Kitware Robot (administrator) 2016-08-12 09:59 |
2014-01-22 11:54 | Dan Lipsa | New Issue | |
2014-01-29 09:33 | Dan Lipsa | Note Added: 0032229 | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038500 | |
