0014541 | ParaView | (No Category) | public | 2014-01-25 14:32 | 2016-08-12 09:59 | ||||
Reporter | j | ||||||||
Summary | 0014541: Possibly faullty data offset counting for Base64 encoded data in AppendData-section | ||||||||
Description | Dear All, Paraview 13.12.0 (32bit) seems to read VTK AppendedData in a peculiar and possibly faulty way. According to the documentation of VTK XML format, the data (later the raw data) of each <DataArray .... format="appended" offset="N"/> <DataArray .... format="appended" offset="N2"/> <DataArray .... format="appended" offset="N3"/> section is stored in <AppendedData> section as follows: It starts with the total length of the data expressed as int32 (MMMM). It is followed by the data from each of the DataArray sections in a continuous manner (AAAA,BBBB,CCCCC..): <AppendedData encoding="raw"> _MMMMAAAAAAAAAAAAAAAABBBBCCCCCCCCCCCCCCCCCCCC </DataArray> The offset expresses the location of each section; N bytes offset from the beginning of the first data section (N=0 ~ 33th bit). Here N_A=0,N_B=16,N_C=20, M=40. However, if the data is base64 encoded, <AppendedData encoding="Base64"> _Base64[MMMMAAAAAAAAAAAAAAAABBBBCCCCCCCCCCCCCCCCCCCC] </DataArray> every byte (8bits) in the encoded string correspond to six bytes of the raw data. Again the offset is based again at the start of the actual data (N=0 is now the 45th bit). However, the offset N correspond to N chars of encoded array, that is 6N bit or 3N/4 bytes of raw data. As a result the offset does not in general correspond to any byte-boundary of the raw data and never corresponds to a char-boundary of the encoded data. In addition, to allow reference to the start of a data section, previous data has to be padded to a multiple of 3 bytes; or as float32 corresponds to 4 bytes, the data has to padded to a multiple of 12 bytes (3xfloats32). Questions: 1) Is this true for VTK+base64 at large or only paraview 2) If not for which versions of VTK / paraview 3) Is this a stable arrangement - should I write my code to adhere? I attach an example of the bit alignment and a vts-file for testing (without debugger, change the alignment of rho-data and save-data in csv). This is data is for debugging reasons stored as UInt8, but the phenomenon is independent of the data type. Paraview 13.12.0 (32bit) Linux 3.2.0-58-generic-pae #88-Ubuntu SMP 2013 i686 i686 i386 GNU/Linux With preciation for any comments. J. EXAMPLE OF THE ALIGNMENT ======================================== |running bit |C = byte.bit encoded data |D = byte.bit orginal data |comment ======================================== ---- byte 0 in base64 code ------- 0 0.8 1 0.7 2 0.6 0.8 data length, byte 0 3 0.5 0.7 4 0.4 0.6 5 0.3 0.5 6 0.2 0.4 7 0.1 0.3 ---- byte 1 in base64 code ------- 8 1.8 9 1.7 10 1.6 0.2 11 1.5 0.1 12 1.4 1.8 data length, byte 1 13 1.3 1.7 14 1.2 1.6 15 1.1 1.5 ---- byte 2 in base64 code ------- 16 2.8 17 2.7 18 2.6 1.4 19 2.5 1.3 20 2.4 1.2 21 2.3 1.1 22 2.2 2.8 data length, byte 2 23 2.1 2.7 ---- byte 3 in base64 code ------- 24 3.8 25 3.7 26 3.6 2.6 27 3.5 2.5 28 3.4 2.4 29 3.3 2.3 30 3.2 2.2 31 3.1 2.1 ---- byte 4 in base64 code ------- 32 4.8 33 4.7 34 4.6 3.8 data length, byte 3 35 4.5 3.7 36 4.4 3.6 37 4.3 3.5 38 4.2 3.4 39 4.1 3.3 ---- byte 5 in base64 code ------- 40 5.8 41 5.7 42 5.6 3.2 43 5.5 3.1 44 5.4 4.8 offset=0; data byte 0; 45 5.3 4.7 46 5.2 4.6 47 5.1 4.5 ---- byte 6 in base64 code ------- 48 6.8 49 6.7 50 6.6 4.4 51 6.5 4.3 52 6.4 4.2 offset=1; 53 6.3 4.1 54 6.2 5.8 data byte 1; 55 6.1 5.7 ---- byte 7 in base64 code ------- 56 7.8 57 7.7 58 7.6 5.6 59 7.5 5.5 60 7.4 5.4 offset=2; 61 7.3 5.3 62 7.2 5.2 63 7.1 5.1 ---- byte 8 in base64 code ------- 64 8.8 65 8.7 66 8.6 6.8 data byte 2; 67 8.5 6.7 68 8.4 6.6 offset=3; 69 8.3 6.5 70 8.2 6.4 71 8.1 6.3 ---- byte 9 in base64 code ------- 72 9.8 73 9.7 74 9.6 6.2 75 9.5 6.1 76 9.4 7.8 offset=4; data byte 3; 77 9.3 7.7 78 9.2 7.6 79 9.1 7.5 ---- byte 10 in base64 code ------- 80 10.8 81 10.7 82 10.6 7.4 83 10.5 7.3 84 10.4 7.2 offset=5; 85 10.3 7.1 86 10.2 8.8 data byte 4; 87 10.1 8.7 ---- byte 11 in base64 code ------- 88 11.8 89 11.7 90 11.6 8.6 91 11.5 8.5 92 11.4 8.4 offset=6; 93 11.3 8.3 94 11.2 8.2 95 11.1 8.1 ---- byte 12 in base64 code ------- 96 12.8 97 12.7 98 12.6 9.8 data byte 5; 99 12.5 9.7 100 12.4 9.6 offset=7; 101 12.3 9.5 102 12.2 9.4 103 12.1 9.3 ---- byte 13 in base64 code ------- 104 13.8 105 13.7 106 13.6 9.2 107 13.5 9.1 108 13.4 10.8 offset=8; data byte 6; 109 13.3 10.7 110 13.2 10.6 111 13.1 10.5 112 13.0 10.4 | ||||||||
Tags | Base64, VTK, XML | ||||||||
Project | TBD | ||||||||
Attached Files | test1.vts [^] (581 bytes) 2014-01-25 14:32 test.vts [^] (2,225 bytes) 2014-01-25 21:17 | ||||||||
(0032217) j (reporter) 2014-01-25 15:18 edited on: 2014-01-25 21:16 |
Correction The attached correct testfile test.vts, the data section contains numbers 1 to 1250 modulo 87. The offset=11 gives the coordinates thecorrect values and the "rho" variable obtains the following values from the original data array: |00100100|00101000|00101100|00110000|00110100 = bits |36______|40______|44______|48______|52______ = rho _______|10______|11______|12______|13______|_ = original data |
(0038502) Kitware Robot (administrator) 2016-08-12 09:59 |
2014-01-25 14:32 | j | New Issue | |
2014-01-25 14:32 | j | File Added: test1.vts | |
2014-01-25 14:38 | j | Tag Attached: Base64 | |
2014-01-25 14:38 | j | Tag Attached: VTK | |
2014-01-25 14:38 | j | Tag Attached: XML | |
2014-01-25 15:18 | j | Note Added: 0032217 | |
2014-01-25 15:21 | j | Note Added: 0032218 | |
2014-01-25 21:16 | j | Note Edited: 0032217 | |
2014-01-25 21:16 | j | Note Deleted: 0032218 | |
2014-01-25 21:17 | j | File Added: test.vts | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038502 | |
