0014572 | ParaView | (No Category) | public | 2014-02-13 15:18 | 2014-08-29 11:00 | ||||
Assigned To | Sankhesh Jhaveri | ||||||||
Summary | 0014572: Chart Panels: Searching doesn't work in the Series Parameters widget | ||||||||
Description | + Open disk_out_ref.ex2, enable all variables. apply + Create plot over line filter, apply + Make the "Series Parameter" table widget on the Properties panel, active by clicking in it. Then hit Ctrl+F. Search widget should pop up. + Try trying the name of one of the series array it it, as you type the text, if should highlight the array. It doesn't. However if you do type incorrect text i.e text not matching any array names, it does go red as expected. So looks like it's half working. My guess is that it's working for QTreeWidget instances, but not for QTreeView instances. | ||||||||
Project | Sandia | ||||||||
Topic Name | 14572-search-series-parameter-widget | ||||||||
(0032416) Sankhesh Jhaveri (developer) 2014-02-26 15:11 |
commit 6e6c4406f7ce7417284722ef07e853bf51efcc96 Author: Sankhesh Jhaveri <sankhesh.jhaveri@kitware.com> Date: Tue Feb 25 12:59:21 2014 -0500 ENH: Added test for pqItemViewSearchWidget (FindWidget) Added custom test event player for pqItemViewSearchWidget Moved pqHighlightItemDelegate class to pqComponents Fixes issue 14572 Change-Id: Ic33efe28905cff173962a1d86f5fdde8efcf0779 commit b33652c77902abec3528b90ac4fa735fdfc79e95 Author: Sankhesh Jhaveri <sankhesh.jhaveri@kitware.com> Date: Fri Feb 21 11:02:08 2014 -0500 ENH: Added a new item delegate class to handle highlighting items The class is currently used to highlight and unhighlight items matched by the pqItemViewSearchWidget This fixes issue 14572. Change-Id: If88c665e1b0441aac456b62ee69a67662db301a2 |
(0032426) Utkarsh Ayachit (administrator) 2014-02-27 11:29 |
reopening -- dashboard issues. |
(0032434) Sankhesh Jhaveri (developer) 2014-02-27 17:01 |
commit 5a4b463f6ce8815efd711ca32c61a8d25ac8e32e Author: Sankhesh Jhaveri <sankhesh.jhaveri@kitware.com> Date: Thu Feb 27 14:53:42 2014 -0500 BUG: Use the correct Export macro This fixes issue 14572 Change-Id: Ib24ce8f5d53857b51d16b50681d9f65063443609 |
(0032463) Utkarsh Ayachit (administrator) 2014-03-09 13:24 |
SUMMARY --------------------------------------------- Topics merged into master: 13794_fix_mp4py 14572-search-series-parameter-widget 14620_FixRulerCrash disabled-multiblock-pieces fix_example_qt5 optimize_amrconnectivity point-sprite-plugin-crash pvweb-visualizer remove-extra-resources (VTK) update-vtk-20140303 ------------------------------------------- |
(0032567) Alan Scott (manager) 2014-04-08 21:00 |
Tested master, Linux, local server. |
2014-02-13 15:18 | Utkarsh Ayachit | New Issue | |
2014-02-13 15:18 | Utkarsh Ayachit | Assigned To | => Sankhesh Jhaveri |
2014-02-17 11:18 | Utkarsh Ayachit | Summary | Searching doesn't work in the Series Parameters widget => Chart Panels: Searching doesn't work in the Series Parameters widget |
2014-02-17 11:18 | Utkarsh Ayachit | Status | backlog => todo |
2014-02-26 15:11 | Sankhesh Jhaveri | Topic Name | => 14572-search-series-parameter-widget |
2014-02-26 15:11 | Sankhesh Jhaveri | Note Added: 0032416 | |
2014-02-26 15:11 | Sankhesh Jhaveri | Status | todo => gatekeeper review |
2014-02-26 15:11 | Sankhesh Jhaveri | Fixed in Version | => git-master |
2014-02-26 15:11 | Sankhesh Jhaveri | Resolution | open => fixed |
2014-02-27 11:29 | Utkarsh Ayachit | Note Added: 0032426 | |
2014-02-27 11:29 | Utkarsh Ayachit | Status | gatekeeper review => todo |
2014-02-27 17:01 | Sankhesh Jhaveri | Note Added: 0032434 | |
2014-02-27 17:01 | Sankhesh Jhaveri | Status | todo => gatekeeper review |
2014-03-09 13:24 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-03-09 13:24 | Utkarsh Ayachit | Note Added: 0032463 | |
2014-04-08 21:00 | Alan Scott | Note Added: 0032567 | |
2014-04-08 21:00 | Alan Scott | Status | customer review => closed |
2014-06-17 09:22 | Utkarsh Ayachit | Target Version | => 4.2 |
2014-08-29 11:00 | Utkarsh Ayachit | Fixed in Version | git-master => 4.2 |
