0014579 | ParaView | (No Category) | public | 2014-02-17 05:32 | 2016-08-12 09:59 | ||||
Reporter | Eugenio | ||||||||
Product Version | 4.1 | ||||||||
Summary | 0014579: Applying Threshold to a TableToPoints yields wrong results | ||||||||
Description | Hello, steps to reproduce the bug: 1. Import the attached CSV file 2. Apply TableToPoints filter, choosing columns X->X, Y->Y, Z->Z 3. Apply a Threshold filter 4. The resulting is empty or sometimes wrong For example: after step 2 we can check in a spreadsheet view that the field "VALUE" is 0 for about one third of the points, 1 for another third, 2 for another third. However, applying the threshold on field VALUE for the range 0-0 yields an empty dataset. Same happnes with ranges 0-1, 1-2, etc. Sometimes, messing around with the thresholds, the resulting dataset is equal to the original one. Additional informations: sometimes I get a "Could not determine array range" error. This happens with both 4.1.0 and 4.0.1. Note: I think I selected the project "Paraview" for this bug report, but there is another "Probject" box where there is no "Paraview" anymore. Sorry, where am I wrong? Note 2: there are other minor problems with the threshold (e.g. the range is not scaled automatically after choosing the field, but only after selecting a specific value - older versions of Paraview behaved correctly instead), but I guess these are to be filled separately? | ||||||||
Project | TBD | ||||||||
Attached Files | devmap_db_0.05.rank0.csv [^] (2,833 bytes) 2014-02-17 05:32 | ||||||||
(0038514) Kitware Robot (administrator) 2016-08-12 09:59 |
2014-02-17 05:32 | Eugenio | New Issue | |
2014-02-17 05:32 | Eugenio | File Added: devmap_db_0.05.rank0.csv | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038514 | |
