0014597 | ParaView | (No Category) | public | 2014-02-25 08:25 | 2016-08-12 09:59 | ||||
Reporter | David C. Lonie | ||||||||
Summary | 0014597: GL2PS exports should disable vtkMapper::InterpolateScalarsBeforeMapping. | ||||||||
Description | If enabled, all color is lost from the rendered geometry. The exporter should disable this setting during export and reset it afterwards to the original state. | ||||||||
Project | TBD | ||||||||
(0038519) Kitware Robot (administrator) 2016-08-12 09:59 |
2014-02-25 08:25 | David C. Lonie | New Issue | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038519 | |
