0014603 | ParaView | (No Category) | public | 2014-02-26 12:16 | 2016-08-12 09:59 | ||||
Reporter | Russ Taylor | ||||||||
Product Version | 4.1 | ||||||||
Summary | 0014603: Crash when loading time-series data sets that load fine in 3.98.0 (both 64-bit) | ||||||||
Description | When loading three time-series data sets (velu, velv, vorticity) one after the other, version 4.1 crashes often on the second one and 5 times out of 5 on the third one. The files can be found at http://www.cs.unc.edu/~taylorr/temp/paraview_bug/ [^] in three Zip files at least until 3/1/2014. Found this while doing an in-class demo for my vis class. Was able to install the old version of Paraview and it worked fine. | ||||||||
Project | TBD | ||||||||
Type | crash | ||||||||
(0038520) Kitware Robot (administrator) 2016-08-12 09:59 |
2014-02-26 12:16 | Russ Taylor | New Issue | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038520 | |
