0014605 | ParaView | (No Category) | public | 2014-02-26 17:58 | 2016-08-12 09:59 | ||||
Reporter | Russ Taylor | ||||||||
Product Version | 4.1 | ||||||||
Summary | 0014605: Reading a table with strings in it, then table to points, can't do calculations | ||||||||
Description | This is also present in 3.98.0. Both 64-bit versions. If you use the CSV reader to load the attached file (paste a "tab" character into the field), you get a table with a string row and then some integer rows. If you use Table to Points with the first numerical column as X and Y and use 2D points, you get a line of points with values associated. If you then use the Calculator to pass through the final field (count of proteins), you get all sorts of strange values. After trying a bunch of things involving making sure that the integer values were read as doubles, adding a header to the file, and converting to 3D points and then pulling out coordZ using the calculator (none of which worked), I finally tried just pulling the character-string field out of the file read by the table. When I did this, the calculator filter worked fine on even the integer data. So it looks like the presence of a character field in the CSV-read table causes Paraview to not be able to deal correctly with some of the other table entries. | ||||||||
Project | TBD | ||||||||
Attached Files | GSM1081542_smc3_TEV.nodup.chr22.wig.txt.zip [^] (360,228 bytes) 2014-02-26 17:58 | ||||||||
(0038522) Kitware Robot (administrator) 2016-08-12 09:59 |
2014-02-26 17:58 | Russ Taylor | New Issue | |
2014-02-26 17:58 | Russ Taylor | File Added: GSM1081542_smc3_TEV.nodup.chr22.wig.txt.zip | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038522 | |
