0014608 | ParaView | (No Category) | public | 2014-02-26 20:39 | 2016-08-12 09:59 | ||||
Assigned To | Sankhesh Jhaveri | ||||||||
Product Version | 4.1 | ||||||||
Summary | 0014608: TextureMaPToPlane doesn't seem to work with slice. | ||||||||
Description | TextureMapToPlane doesn't work on slices. This should be fixed. Local server, Linux, 4.1.0. Wavelet. Apply. Slice. Z Normal. Apply. TextureMapToPlane. Apply. Now, texture by a picture. I used frame 4 of the can.0004.png movie. You never see a texture appear. This is a bug. | ||||||||
Project | Sandia | ||||||||
(0032428) Utkarsh Ayachit (administrator) 2014-02-27 12:18 edited on: 2014-02-27 12:20 |
To overcome this issue, set coloring mode to "Solid Color". Texture and scalar coloring doesn't work together when coloring by point-data. You can turn off "Interpolate Scalars Before Mapping" from the properties panel, and then blending of point scalar colors and texture does work again. |
(0032431) Utkarsh Ayachit (administrator) 2014-02-27 12:27 |
customer review for feedback. Please reopen if needed. |
(0032446) Alan Scott (manager) 2014-03-03 14:56 |
Utkarsh and I discussed. From Utkarsh: I think it's reasonable to expect ParaView to turn off "Interpolate Scalars Before Mapping" automatically when the user loads a texture. |
(0036516) Alan Scott (manager) 2016-07-14 21:16 |
Still an issue in 5.1.1 |
(0038524) Kitware Robot (administrator) 2016-08-12 09:59 |
2014-02-26 20:39 | Alan Scott | New Issue | |
2014-02-27 12:18 | Utkarsh Ayachit | Note Added: 0032428 | |
2014-02-27 12:19 | Utkarsh Ayachit | Note Edited: 0032428 | |
2014-02-27 12:20 | Utkarsh Ayachit | Note Edited: 0032428 | |
2014-02-27 12:27 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2014-02-27 12:27 | Utkarsh Ayachit | Resolution | open => no change required |
2014-02-27 12:27 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2014-02-27 12:27 | Utkarsh Ayachit | Note Added: 0032431 | |
2014-02-27 12:27 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-03-03 14:56 | Alan Scott | Note Added: 0032446 | |
2014-03-03 14:56 | Alan Scott | Status | customer review => todo |
2014-03-21 00:03 | Utkarsh Ayachit | Assigned To | Utkarsh Ayachit => Sankhesh Jhaveri |
2016-07-14 21:16 | Alan Scott | Note Added: 0036516 | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038524 | |
2016-08-12 09:59 | Kitware Robot | Status | todo => closed |
2016-08-12 09:59 | Kitware Robot | Resolution | no change required => moved |
