0001461 | ParaView | (No Category) | public | 2005-01-07 13:54 | 2016-08-12 09:57 | ||||
Reporter | Lee Ankeny | ||||||||
Summary | 0001461: LA: renderserver and tiled display are incompatible | ||||||||
Description | Tiled-display works, and client/server/renderserver works, but they don't work together anymore. Below are the three commandlines and the ensuing errors. In this case I'm using a non-parallel build of PV 1.8, but the same problem occurs with MPI and with the CVS trunk. This worked in 1.6, and I thought it worked in 1.8 at one time, but possibly not. ====================================== ib000.viz.acl.lanl.gov|/home/laa> /usr/local/paraview/Dashboards/MyTests/ib/zRel18-Linux-gcc-none-MinSizeRel/bin/paraview -rs -m=rshostfile Listen on port: 22221 RenderServer: Waiting for client... connected to port 22221 Client connected. Connect: id :0 host: ib001 Port:11111 ERROR: In /usr/local/paraview/Dashboards/MyTests/ParaView-1-8/VTK/Parallel/vtkSocketCommunicator.cxx, line 572 vtkSocketCommunicator (0x98a75b8): Could not receive tag. 315167 ERROR: In /usr/local/paraview/Dashboards/MyTests/ParaView-1-8/VTK/Parallel/vtkMultiProcessController.cxx, line 354 vtkSocketController (0x98c4470): Could not receive RMI trigger message. Exit Render Server. ====================================== ib001.viz.acl.lanl.gov|/home/laa> /usr/local/paraview/Dashboards/MyTests/ib/zRel18-Linux-gcc-none-MinSizeRel/bin/pvserver -m=dshostfile Listen on port: 11111 Waiting for client... connected to port 11111 Client connected. open with port 11111 WaitForConnection: id :0 Port:11111 Received Hello from process 0 ERROR: In /usr/local/paraview/Dashboards/MyTests/ParaView-1-8/VTK/Parallel/vtkSocketCommunicator.cxx, line 572 vtkSocketCommunicator (0x9329610): Could not receive tag. 315167 ERROR: In /usr/local/paraview/Dashboards/MyTests/ParaView-1-8/VTK/Parallel/vtkMultiProcessController.cxx, line 354 vtkSocketController (0x9346f08): Could not receive RMI trigger message. Exit Data Server. ====================================== ib028.viz.acl.lanl.gov|/home/laa> /usr/local/paraview/Dashboards/MyTests/ib/zRel18-Linux-gcc-none-MinSizeRel/bin/paraview -crs -r2d -rsh=ib000 -h=ib001 -tdx=1 -tdy=1 Connect to ib001:11111 Connect to ib000:22221 Object type: vtkMPIMoveData, could not find requested method: "SetMPIMToNSocketConnection" or the method was called with incorrect arguments. Abort (core dumped) ================================================== dshostfile contains: ib001 rshostfile contains: ib000 | ||||||||
(0001959) 2005-01-21 14:28 |
This has been corrected in the CVS version of ParaView. |
(0001960) Amy Squillacote (reporter) 2005-01-21 14:28 |
This has been corrected in the CVS (trunk) version of ParaView. |
(0002006) Lee Ankeny (reporter) 2005-01-31 13:56 |
Now using tiled-display mode doesn't crash, but the image doesn't show on the tiles either. This is true in both client/server and client/server/renderserver modes. e.g.: mpirun -np 1 -H ib004 pvrenderserver -m=rshostfile -tdx=1 -tdy=1 mpirun -np 1 -H ib000 pvdataserver -m=dshostfile mpirun -np 1 -H ib031 pvclient -r2d -crs -dsh=ib000 -rsh=ib004 and: mpirun -np 1 -H ib004 pvserver -tdx=1 -tdy=1 mpirun -np 1 -H ib031 pvclient --server-host=ib004 I've tried vtkPVMultiDisplayRenderModule with the same results. |
(0002009) Amy Squillacote (reporter) 2005-02-01 09:21 |
Actually vtkPVMultiDisplayRenderModule does work with a tiled display, but we discovered yesterday that you could not set the render module from the command line. (That has been corrected now; the --render-module argument works on the client's command line.) Now I still need to find out wht the IceTRenderModule (the default) does not work with a tiled display. |
(0002035) Amy Squillacote (reporter) 2005-02-03 13:46 |
The image shows up now (main CVS tree). |
(0002043) Lee Ankeny (reporter) 2005-02-04 16:42 |
Hmmm... It's still not working for me. All three processes start, but there's no picture on the wall. Besides that, client/server mode is now screwed up. I find that when using multiple tiles the first tile shows its imagein the wrong position. It has also become extremely slow. This is all with last night's (03-Feb-2005) trunk version. |
(0002228) Amy Squillacote (reporter) 2005-03-23 10:26 |
From an e-mail from Lee on 3-16-2005: The way we left it was that it worked (got it working while you were here), but it was extremely slow. It also needs an automated test, on multiple hosts, to ensure it hasn't come back. |
(0037489) Kitware Robot (administrator) 2016-08-12 09:57 |
2009-12-10 06:52 | Berk Geveci | Status | backlog => tabled |
2009-12-10 06:52 | Berk Geveci | Assigned To | Amy Squillacote => Utkarsh Ayachit |
2016-08-12 09:57 | Kitware Robot | Note Added: 0037489 | |
2016-08-12 09:57 | Kitware Robot | Resolution | reopened => moved |
