0014616 | ParaView | (No Category) | public | 2014-03-03 17:19 | 2014-08-29 11:00 | ||||
Summary | 0014616: developer tag: Remove obsolete code | ||||||||
Description | Remove obsolete code for managing "extra-resources" from Qt/Components. | ||||||||
Project | Kitware | ||||||||
Topic Name | remove-extra-resources | ||||||||
(0032447) Utkarsh Ayachit (administrator) 2014-03-03 17:20 |
commit de66764ae4f47a3edb76b00403e4888047feec69 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Mon Mar 3 17:12:52 2014 -0500 Remove obsolete Extra-Resources logic. This logic was used in pre-3.12 days when developers added compile time extensions to ParaView. Removed this obsolete logic which was causing build errors in some cases. Change-Id: Idc4d9c36951d6f0f8e46c6877f8d5b787fed70e7 |
(0032467) Utkarsh Ayachit (administrator) 2014-03-09 13:24 |
SUMMARY --------------------------------------------- Topics merged into master: 13794_fix_mp4py 14572-search-series-parameter-widget 14620_FixRulerCrash disabled-multiblock-pieces fix_example_qt5 optimize_amrconnectivity point-sprite-plugin-crash pvweb-visualizer remove-extra-resources (VTK) update-vtk-20140303 ------------------------------------------- |
(0032513) Alan Scott (manager) 2014-03-20 21:36 |
Developer tag in Git. Closed. Thanks for making it so easy to figure out if I should test this bug! Adding developer tag to the front helps a lot. |
2014-03-03 17:19 | Utkarsh Ayachit | New Issue | |
2014-03-03 17:20 | Utkarsh Ayachit | Topic Name | => remove-extra-resources |
2014-03-03 17:20 | Utkarsh Ayachit | Note Added: 0032447 | |
2014-03-03 17:20 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2014-03-03 17:20 | Utkarsh Ayachit | Fixed in Version | => git-next |
2014-03-03 17:20 | Utkarsh Ayachit | Resolution | open => fixed |
2014-03-03 17:20 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2014-03-09 13:24 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2014-03-09 13:24 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-03-09 13:24 | Utkarsh Ayachit | Note Added: 0032467 | |
2014-03-20 21:36 | Alan Scott | Note Added: 0032513 | |
2014-03-20 21:36 | Alan Scott | Status | customer review => closed |
2014-06-17 09:22 | Utkarsh Ayachit | Target Version | => 4.2 |
2014-08-29 11:00 | Utkarsh Ayachit | Fixed in Version | git-master => 4.2 |
