0014624 | ParaView | (No Category) | public | 2014-03-07 11:56 | 2016-08-12 09:59 | ||||
Reporter | Ganesh Vijayakumar | ||||||||
Product Version | 4.1 | ||||||||
Summary | 0014624: Opacity | ||||||||
Description | Reducing opacity from 1.0 on a surface representation causes errors. Many times it produces images with broken lines. Steps to reproduce: 1. Open Paraview 2. Create Cylinder source 3. Reduce opacity under "Styling" in the Properties window. Produces errors like below. ERROR: In C:\DBD\pvs-x64\paraview\src\paraview\VTK\Rendering\OpenGL\vtkOpenGLDisplayListPainter.cxx, line 188 vtkOpenGLDisplayListPainter (0000000011CF03C0): failed after RenderInternal 1 OpenGL errors detected 0 : (1282) Invalid operation ERROR: In C:\DBD\pvs-x64\paraview\src\paraview\VTK\Rendering\OpenGL\vtkOpenGLDisplayListPainter.cxx, line 188 vtkOpenGLDisplayListPainter (0000000011CF03C0): failed after RenderInternal 1 OpenGL errors detected 0 : (1282) Invalid operation ERROR: In C:\DBD\pvs-x64\paraview\src\paraview\VTK\Rendering\OpenGL\vtkOpenGLDisplayListPainter.cxx, line 188 vtkOpenGLDisplayListPainter (0000000011CF03C0): failed after RenderInternal 1 OpenGL errors detected 0 : (1282) Invalid operation I attach a file where the opacity produces broken lines. However, this was produced using Paraview 3.14 using pvbatch. | ||||||||
Project | TBD | ||||||||
Attached Files | isosurface_0.06.jpg [^] (39,336 bytes) 2014-03-07 11:56
(0032477) Alan Scott (manager) 2014-03-11 15:19 |
This is very, very likely a driver issue/ bug. Try this test on a different OS and/or system? |
(0038531) Kitware Robot (administrator) 2016-08-12 09:59 |
2014-03-07 11:56 | Ganesh Vijayakumar | New Issue | |
2014-03-07 11:56 | Ganesh Vijayakumar | File Added: isosurface_0.06.jpg | |
2014-03-11 15:19 | Alan Scott | Note Added: 0032477 | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038531 | |
