0014631 | ParaView | (No Category) | public | 2014-03-10 13:14 | 2014-08-29 10:59 | ||||
Assigned To | Ben Boeckel (Kitware) | ||||||||
Target Version | Fixed in Version | 4.2 | |||||||
Summary | 0014631: Update ParaView to use same mechanism as VTK for data and test baselines. | ||||||||
Description | Need to update ParaView to use the same mechanism as VTK for data and baseline. Kyle started work on this. There's a topic on ParaView stage named "external-data". | ||||||||
Project | Sandia | ||||||||
Topic Name | use-external-data | ||||||||
Type | feature | ||||||||
(0032472) Ben Boeckel (Kitware) (developer) 2014-03-10 19:46 |
I've emailed sysadmin to create a ParaView community on the MIDAS instance (I don't have enough permissions to do so). It looks like there might be a way to move Kyle's collection to another community, but that probably needs site admin or community admin rights. |
(0032479) Utkarsh Ayachit (administrator) 2014-03-12 12:50 |
Also, VTK tests don't seem to run correctly from within ParaView. Looks like it's looking for Data under a different location than where it is. e.g. try running the vtkIOEnSightPython-EnSight6Elements test from a ParaView build. It will fail to find the data. |
(0032601) Ben Boeckel (Kitware) (developer) 2014-04-16 17:33 |
It looks like there are some failing tests due to the branch :( . Investigating. |
(0033187) Ben Boeckel (Kitware) (developer) 2014-08-06 17:22 |
This has been done. |
(0033210) Utkarsh Ayachit (administrator) 2014-08-13 10:22 |
SUMMARY --------------------------------------------- Topics merged into master: 14894-fix-vgl-renderer (VTK) 14913_fix_widget_enabled_state 14918_fix_color_palette_restore (VTK) autobahn-update-http-endpoints fix-extras-catalyst-patch lazy_update_enabled_filters mpas-changes (VTK) newest-xdmf pvweb-update-to-generic-decorators pvweb-visualizer-busy-until-connected quieter-cuda-discovery remove_analyze rename-coproc-script-gen scalar-reset-button static-numpy transparent-png-views ui_fixes |
(0033248) Alan Scott (manager) 2014-08-18 20:53 |
Developer tag in git. Closing. |
2014-03-10 13:14 | Utkarsh Ayachit | New Issue | |
2014-03-10 13:14 | Utkarsh Ayachit | Assigned To | => Ben Boeckel (Kitware) |
2014-03-10 19:46 | Ben Boeckel (Kitware) | Note Added: 0032472 | |
2014-03-12 12:50 | Utkarsh Ayachit | Note Added: 0032479 | |
2014-04-16 17:33 | Ben Boeckel (Kitware) | Note Added: 0032601 | |
2014-04-16 17:34 | Ben Boeckel (Kitware) | Topic Name | => use-external-data |
2014-04-16 17:34 | Ben Boeckel (Kitware) | Type | incorrect functionality => feature |
2014-04-16 17:34 | Ben Boeckel (Kitware) | Status | backlog => active development |
2014-08-06 17:22 | Ben Boeckel (Kitware) | Note Added: 0033187 | |
2014-08-06 17:22 | Ben Boeckel (Kitware) | Status | active development => gatekeeper review |
2014-08-13 10:21 | Utkarsh Ayachit | Fixed in Version | => git-master |
2014-08-13 10:22 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-08-13 10:22 | Utkarsh Ayachit | Note Added: 0033210 | |
2014-08-18 20:53 | Alan Scott | Note Added: 0033248 | |
2014-08-18 20:53 | Alan Scott | Status | customer review => closed |
2014-08-18 20:53 | Alan Scott | Resolution | open => fixed |
2014-08-29 10:59 | Utkarsh Ayachit | Fixed in Version | git-master => 4.2 |
