0014632 | ParaView | (No Category) | public | 2014-03-11 13:40 | 2014-04-08 17:57 | ||||
Reporter | Jeff Mauldin | ||||||||
Assigned To | Sankhesh Jhaveri | ||||||||
Product Version | 4.1 | ||||||||
Summary | 0014632: Find Data Dialog: 'query' drop down allows no way to see enough variable name to pick correctly | ||||||||
Description | In the "Find Data" dialog, there is a dropdown for creating a query which lets you select "query" or a data item (such as stress_xy). It is so narrow that only the most terse variable names (e.g. maybe 4 chars or less) are completely visible, and there is no way to see the whole variable name. For cases like a stress tensor, with stress_xx, stress_zx, etc. more than one variable gets the same abbreviated label and there is no way to see the whole label (changing it into a query pulls the variable name into the query box which helps). The dropdown needs to expand wider and/or we need a tool tip or something, or a way to select while seeing whole variable names. | ||||||||
Project | Sandia | ||||||||
Topic Name | 14632-find-data-query-combobox | ||||||||
(0032489) Utkarsh Ayachit (administrator) 2014-03-19 23:59 |
Basically, the "criteria" combo-box in the pqQuertyClauseWidget.ui needs to be fixed to use the right sizeAdjustPolicy. Change it to AdjustToContents, rather than AdjustToContentsoonFirstShow. |
(0032502) Sankhesh Jhaveri (developer) 2014-03-20 18:46 |
commit 081de6fadece325d8d22a2a7847d49e8c4e7feb1 Author: Sankhesh Jhaveri <sankhesh.jhaveri@kitware.com> Date: Thu Mar 20 18:45:09 2014 -0400 Fix sizeAdjustPolicy of criteria box in FindData dialog Change-Id: Id4b81f49a2d6707763d28576d1bb522e1c56a43a Qt/Components/Resources/UI/pqQueryClauseWidget.ui | 6 +++++- 1 file changed, 5 insertions(+), 1 deletion(-) |
(0032540) Utkarsh Ayachit (administrator) 2014-03-28 11:55 |
--------------------------------------------- Topics merged into master: 14557-color-legend-update 14580-top-level-checkbox (VTK) 14615-fix-mpi-segfault 14650_check_bounds catalyst-web delaunay3d-alpha-bools fix_qt5_dashboard_failures pvweb-doc-update (VTK) vtk_02_20_2014 14632-find-data-query-combobo |
(0032552) Alan Scott (manager) 2014-04-08 17:57 |
Tested remote server, Linux, master. |
2014-03-11 13:40 | Jeff Mauldin | New Issue | |
2014-03-19 23:58 | Utkarsh Ayachit | Assigned To | => Sankhesh Jhaveri |
2014-03-19 23:59 | Utkarsh Ayachit | Note Added: 0032489 | |
2014-03-20 16:47 | Utkarsh Ayachit | Status | backlog => todo |
2014-03-20 18:46 | Sankhesh Jhaveri | Topic Name | => 14632-find-data-query-combobox |
2014-03-20 18:46 | Sankhesh Jhaveri | Note Added: 0032502 | |
2014-03-20 18:46 | Sankhesh Jhaveri | Status | todo => gatekeeper review |
2014-03-20 18:46 | Sankhesh Jhaveri | Resolution | open => fixed |
2014-03-28 11:55 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-03-28 11:55 | Utkarsh Ayachit | Note Added: 0032540 | |
2014-04-08 17:57 | Alan Scott | Note Added: 0032552 | |
2014-04-08 17:57 | Alan Scott | Status | customer review => closed |
