0014712 | ParaView | (No Category) | public | 2014-05-02 11:48 | 2016-08-12 09:59 | ||||
Reporter | Dan Lipsa | ||||||||
Summary | 0014712: Catalyst script with a writer fails when one of the pipeline source is downloaded in ParaView | ||||||||
Description | Run bin/pvpython ~/test/waveletdriver.py coprocessing-wavelet-views2 1000 Tools/Connect to Catalyst Click on the Extract icon for the Slice pipeline object. The Catalyst script fails with Warning: In /home/danlipsa/src/ParaView-live-breakpoint/ParaViewCore/VTKExtensions/Core/vtkPVTrivialProducer.cxx, line 123 vtkPVTrivialProducer (0x346c2d0): Requesting time 0.016 but only 0.017 is available ERROR: In /home/danlipsa/src/ParaView-live-breakpoint/VTK/Common/ExecutionModel/vtkDemandDrivenPipeline.cxx, line 715 vtkPVCompositeDataPipeline (0x34b8f80): Input port 0 of algorithm vtkXMLPPolyDataWriter(0x34b6890) has 0 connections but is not optional. The two scripts are: waveletdriver.py import sys if len(sys.argv) != 3: print "command is 'python <python driver code> <script name> <number of time steps>'" sys.exit(1) import paraview import paraview.vtk as vtk import paraview.simple as pvsimple import math # initialize and read input parameters paraview.options.batch = True paraview.options.symmetric = True def _refHolderMaker(obj): def _refHolder(obj2, string): tmp = obj return _refHolder def coProcess(grid, time, step, scriptname, wholeExtent): import vtkPVCatalystPython import os scriptpath, scriptname = os.path.split(scriptname) sys.path.append(scriptpath) if scriptname.endswith(".py"): print 'script name is ', scriptname scriptname = scriptname[0:len(scriptname)-3] try: cpscript = __import__(scriptname) except: print sys.exc_info() print 'Cannot find ', scriptname, ' -- no coprocessing will be performed.' sys.exit(1) return datadescription = vtkPVCatalystPython.vtkCPDataDescription() datadescription.SetTimeData(time, step) datadescription.AddInput("input") cpscript.RequestDataDescription(datadescription) inputdescription = datadescription.GetInputDescriptionByName("input") if inputdescription.GetIfGridIsNecessary() == False: return inputdescription.SetGrid(grid) if grid.IsA("vtkImageData") == True or grid.IsA("vtkRectilinearGrid") == True \ or grid.IsA("vtkStructuredGrid") == True: inputdescription.SetWholeExtent(wholeExtent) cpscript.DoCoProcessing(datadescription) try: numsteps = int(sys.argv[2]) except ValueError: print 'the last argument should be a number' numsteps = 10 #imageData2 = vtk.vtkImageData() for step in range(numsteps): print "Timestep ", step # assume simulation time starts at 0 time = step/float(numsteps) # create the input to the coprocessing library. normally # this will come from the adaptor wavelet = pvsimple.Wavelet() wholeExtent = wavelet.WholeExtent # put in some variation in the point data that changes with time wavelet.Maximum = 255+200*math.sin(step) wavelet.UpdatePipeline() imageData = pvsimple.servermanager.Fetch(wavelet) # note that we delete wavelet now since. if not, it will # get deleted automatically in the coprocessing script pvsimple.Delete(wavelet) wavelet = None # "perform" coprocessing. results are outputted only if # the passed in script says we should at time/step coProcess(imageData, time, step, sys.argv[1], wholeExtent) imageData = None import time time.sleep(1) | ||||||||
Project | TBD | ||||||||
Attached Files | coprocessing-wavelet-views2.py [^] (5,377 bytes) 2014-05-02 11:48 | ||||||||
(0038567) Kitware Robot (administrator) 2016-08-12 09:59 |
2014-05-02 11:48 | Dan Lipsa | New Issue | |
2014-05-02 11:48 | Dan Lipsa | File Added: coprocessing-wavelet-views2.py | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038567 | |
