0014731 | ParaView | (No Category) | public | 2014-05-15 08:56 | 2016-08-12 09:59 | ||||
Reporter | Vadim SANDLER | ||||||||
Product Version | 4.1 | ||||||||
Summary | 0014731: After relaunching a python script, the last scalar bar stays displayed when hiding the representation | ||||||||
Description | Launch the script playing_with_scalar_bar_paraview.py (attached). In the Pipeline Browser, click on the eye left of MeshQuality1. => The representation and the scalar bar are hidden. Re-launch the script. Click on the eye left of MeshQuality2. => The representation is hidden, but the scalar is still displayed. | ||||||||
Project | ParaViS | ||||||||
Attached Files | playing_with_scalar_bar_paraview.py [^] (2,227 bytes) 2014-05-15 08:56 | ||||||||
(0032792) Utkarsh Ayachit (administrator) 2014-06-09 07:23 |
Tristan, have you started working on this? Otherwise I'd like to take this as this may be related to some of my recent changes (unless it's happening in 4.1). |
(0032795) Tristan Coulange (developer) 2014-06-09 07:28 |
Utkarsh, No I did not work on this one, you can take it :) Tristan |
(0032860) Utkarsh Ayachit (administrator) 2014-06-13 15:32 |
Vadim, Alas there's no way to fix this script. The problem is that the script uses the CreateScalarBar call which results in creating a new scalar bar each time. The ParaView application automatically associates the first scalar bar created, and hence it works well the first time you load the script. When you load it the second time, a new scalar bar is created and this one is orphaned. As a result the UI pretty much ignores it. In development ParaView, there's a better way of setting up color bars. DataRepresentation3.SetScalarBarVisibility(GetActiveView(), True) This API is under development and it will be refined by 4.3 release (slated for late fall this year). |
(0038572) Kitware Robot (administrator) 2016-08-12 09:59 |
2014-05-15 08:56 | Vadim SANDLER | New Issue | |
2014-05-15 08:56 | Vadim SANDLER | File Added: playing_with_scalar_bar_paraview.py | |
2014-06-05 11:30 | Joachim Pouderoux | Assigned To | => Tristan Coulange |
2014-06-09 07:23 | Utkarsh Ayachit | Note Added: 0032792 | |
2014-06-09 07:28 | Tristan Coulange | Note Added: 0032795 | |
2014-06-13 06:54 | Tristan Coulange | Assigned To | Tristan Coulange => Utkarsh Ayachit |
2014-06-13 15:32 | Utkarsh Ayachit | Note Added: 0032860 | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038572 | |
