0014733 | ParaView | (No Category) | public | 2014-05-16 06:53 | 2014-08-29 11:00 | ||||
Reporter | Vadim SANDLER | ||||||||
Assigned To | Tristan Coulange | ||||||||
Product Version | 4.1 | ||||||||
Summary | 0014733: Bad computation of the min and max values of a field when the color gradient has been changed by the user | ||||||||
Description | Click on Source > Cone. Apply. Color by field "cellNormals" and component "Z". Display the Color Map. Click on Edit Color map > Choose Preset > Blue to Red Rainbow. Close Click on Save as Default. Close. Click on Source > Sphere. Apply. Create filter "Mesh Quality". Apply. Display the Color Map. The Color Map ranges from -0.918 to 0.918 and should go from 1.06 to 1.64. Clicking on "Rescale to data range" does not solve the problem. | ||||||||
Project | ParaViS | ||||||||
Topic Name | bug_color_save_as_default | ||||||||
(0032749) Joachim Pouderoux (developer) 2014-06-05 10:37 |
Hello, Sorry, I just tried but I am not able to reproduce the issue (with official ParaView 4.1.0 Windows@64bits). At the end, the color map for "Quality" goes from 1.07 to 1.65. |
(0032775) Tristan Coulange (developer) 2014-06-06 11:48 |
I have the bug, I'm working on it. |
(0032866) Tristan Coulange (developer) 2014-06-16 09:21 |
The issue is already fixed into master, but there was a warning message. The bug causing the warning was fixed, and the fix is approved and merged on gerrit: http://review.source.kitware.com/#/t/4276/ [^] BUG: fix the SaveAsDefault in ColorMapEditor When clicking on "Save as default" in the ColorMapEditor, a warning said the property ScalarOpacityFunction was not found. The property was searched in a bad proxy. Now the property is found. Change-Id: Idfd3434f5835fe7faccf0fec9433df891c1ac740 |
(0032874) Utkarsh Ayachit (administrator) 2014-06-17 07:20 |
Topics merged into master: 14720-RemoveQtWebkit 14737-SearchBoxWidget 14799_optionally_hide_catalyst_inputs 14803_remove_redundant_option bug_color_save_as_default fix_warnings misc_lut_fixes |
(0032929) Alan Scott (manager) 2014-06-26 21:42 |
Looks correct. Tested local server, master, Linux. |
2014-05-16 06:53 | Vadim SANDLER | New Issue | |
2014-06-05 10:33 | Joachim Pouderoux | Assigned To | => Joachim Pouderoux |
2014-06-05 10:37 | Joachim Pouderoux | Note Added: 0032749 | |
2014-06-05 10:38 | Joachim Pouderoux | Reproducibility | have not tried => unable to reproduce |
2014-06-06 11:48 | Tristan Coulange | Note Added: 0032775 | |
2014-06-06 11:48 | Tristan Coulange | Assigned To | Joachim Pouderoux => Tristan Coulange |
2014-06-06 11:48 | Tristan Coulange | Reproducibility | unable to reproduce => always |
2014-06-06 11:48 | Tristan Coulange | Status | backlog => active development |
2014-06-16 09:21 | Tristan Coulange | Note Added: 0032866 | |
2014-06-16 09:23 | Tristan Coulange | Topic Name | => bug_color_save_as_default |
2014-06-16 09:23 | Tristan Coulange | Status | active development => gatekeeper review |
2014-06-17 07:20 | Utkarsh Ayachit | Fixed in Version | => git-master |
2014-06-17 07:20 | Utkarsh Ayachit | Note Added: 0032874 | |
2014-06-17 07:28 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-06-17 09:21 | Utkarsh Ayachit | Target Version | => 4.2 |
2014-06-26 21:42 | Alan Scott | Note Added: 0032929 | |
2014-06-26 21:42 | Alan Scott | Status | customer review => closed |
2014-06-26 21:42 | Alan Scott | Resolution | open => fixed |
2014-08-29 11:00 | Utkarsh Ayachit | Fixed in Version | git-master => 4.2 |
