0014756 | ParaView | (No Category) | public | 2014-05-26 09:43 | 2016-08-12 09:59 | ||||
Reporter | Gena Bug | ||||||||
Product Version | 4.1 | ||||||||
Summary | 0014756: crash when removing element from the list of isosurfaces (contour filter) | ||||||||
Description | Hi, Noticed that pv 4.1 crashes when trying to remove element from a list of isosurfaces in Contour filter while none element selected. Steps to reproduce: 1. create Contour filter 1.* deselect element in the list of isosurfaces (none selected by default) 2. push 'remove current element' button 3. profit: ASSERT failure in QVector<T>::at: "index out of range", file /home/utkarsh/Dashboards/MyTests/NightlyMaster/ParaViewSuperbuild-Release/install/include/QtCore/qvector.h, line 351 p.s. pv4.1 for linux 64 bit downloaded from the site was used | ||||||||
Project | TBD | ||||||||
Type | crash | ||||||||
(0038575) Kitware Robot (administrator) 2016-08-12 09:59 |
2014-05-26 09:43 | Gena Bug | New Issue | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038575 | |
