0014784 | ParaView | (No Category) | public | 2014-06-06 10:46 | 2014-08-29 10:59 | ||||
Reporter | Andy Bauer | ||||||||
Assigned To | Andy Bauer | ||||||||
Summary | 0014784: vtkCPPythonScriptPipeline should have process 0 do as much work as possible and broadcast that to other processes | ||||||||
Description | Only process 0 should check that the Python script exists and then read it in vtkCPPythonScriptPipeline. It can broadcast this information to the other processes to save on file IO. | ||||||||
Project | Catalyst | ||||||||
Topic Name | 14784_PythonCatalyst_better_IO | ||||||||
(0032785) Utkarsh Ayachit (administrator) 2014-06-09 06:56 |
fed7bb1 (stage/fix_cmake_warnings) Fix cmake warnings about mixed link types in target_links. |
(0032788) Utkarsh Ayachit (administrator) 2014-06-09 07:01 |
SUMMARY --------------------------------------------- Topics merged into master: 14771_fix_global_annotation_filter 14784_PythonCatalyst_better_IO fix_cmake_warnings fix_size_hint_pqTreeView misc_chart_panel_fixes |
(0032801) Andy Bauer (developer) 2014-06-09 10:31 |
commit 737ca0511a93ff9b3526b08694b55450bf8e84b7 Author: Andrew Bauer <andy.bauer@kitware.com> Date: Fri Jun 6 13:05:41 2014 -0400 Making only process 0 check if the Catalyst script exists. Process 0 now is the only process that checks whether a Catalyst Python script exists and then broadcasts that info to other processes. This is one less way we'll kill the file system when running at scale. Change-Id: I50fc220666d236c6d6f5f49eb89654168ac3e3d0 |
(0032802) Andy Bauer (developer) 2014-06-09 10:34 |
The first commit only did a partial fix. That change had process 0 verify that the Python script existed and broadcast that information to the other processes. The next part is for process 0 to read in the script and broadcast that to the other processes. This could take a bit more care since there are edge cases that need to be tested. |
(0032808) Andy Bauer (developer) 2014-06-09 15:21 |
The next part that needs to be done is still in vtkCPPythonScriptPipeline. In Initialize() it should read in the script contents on process 0 and broadcast that string to the other processes. Then each process can do vtkPythonInterpreter::RunSimpleString(<file contents>) or something like that since it probably also needs to put the methods in that script in a namespace so that other Python script pipelines can be used without clashing. If the namespace is the name of the file without the path or extension then CoProcess() should be able to work without modifications. |
(0033014) Andy Bauer (developer) 2014-07-14 09:39 |
commit 0b163702c75914a7d4dcd22116c18dd16cbc0cf7 Author: Andrew Bauer <andy.bauer@kitware.com> Date: Fri Jul 11 12:52:57 2014 -0400 Windows fix for reading in the Catalyst Python script. Work done by Chuck Atkins so blame him if this doesn't work :). Change-Id: I36e6b52d6816f5a5a9a8d540ae3d1e2e3fdd55ff |
(0033016) Utkarsh Ayachit (administrator) 2014-07-14 10:07 |
SUMMARY --------------------------------------------- Topics merged into master: 14784_PythonCatalyst_better_IO (VTK) newest-xdmf |
(0033122) Alan Scott (manager) 2014-07-28 20:47 |
Developer tag in git. Closing. |
2014-06-06 10:46 | Andy Bauer | New Issue | |
2014-06-06 10:46 | Andy Bauer | Assigned To | => Andy Bauer |
2014-06-06 13:08 | Andy Bauer | Status | backlog => todo |
2014-06-06 13:08 | Andy Bauer | Status | todo => active development |
2014-06-09 06:56 | Utkarsh Ayachit | Topic Name | => 14784_PythonCatalyst_better_IO |
2014-06-09 06:56 | Utkarsh Ayachit | Note Added: 0032785 | |
2014-06-09 06:56 | Utkarsh Ayachit | Status | active development => gatekeeper review |
2014-06-09 06:56 | Utkarsh Ayachit | Fixed in Version | => git-next |
2014-06-09 06:56 | Utkarsh Ayachit | Resolution | open => fixed |
2014-06-09 06:57 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2014-06-09 07:01 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-06-09 07:01 | Utkarsh Ayachit | Note Added: 0032788 | |
2014-06-09 10:31 | Andy Bauer | Note Added: 0032801 | |
2014-06-09 10:34 | Andy Bauer | Note Added: 0032802 | |
2014-06-09 10:34 | Andy Bauer | Status | customer review => backlog |
2014-06-09 10:34 | Andy Bauer | Resolution | fixed => reopened |
2014-06-09 10:34 | Andy Bauer | Assigned To | Andy Bauer => Utkarsh Ayachit |
2014-06-09 15:21 | Andy Bauer | Note Added: 0032808 | |
2014-06-17 09:21 | Utkarsh Ayachit | Target Version | => 4.2 |
2014-06-24 13:30 | Andy Bauer | Assigned To | Utkarsh Ayachit => Andy Bauer |
2014-06-24 13:31 | Andy Bauer | Status | backlog => todo |
2014-07-14 09:39 | Andy Bauer | Status | todo => active development |
2014-07-14 09:39 | Andy Bauer | Note Added: 0033014 | |
2014-07-14 09:39 | Andy Bauer | Status | active development => gatekeeper review |
2014-07-14 09:39 | Andy Bauer | Resolution | reopened => fixed |
2014-07-14 10:07 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-07-14 10:07 | Utkarsh Ayachit | Note Added: 0033016 | |
2014-07-28 20:47 | Alan Scott | Note Added: 0033122 | |
2014-07-28 20:47 | Alan Scott | Status | customer review => closed |
2014-08-29 10:59 | Utkarsh Ayachit | Fixed in Version | git-master => 4.2 |
