0014821 | ParaView | (No Category) | public | 2014-06-24 11:25 | 2015-01-11 08:16 | ||||
Reporter | Vadim SANDLER | ||||||||
Assigned To | Tristan Coulange | ||||||||
Product Version | 4.1 | ||||||||
Target Version | Fixed in Version | 4.2 | |||||||
Summary | 0014821: Long compilation of ParaView with early versions of gcc 4.4 | ||||||||
Description | The compilation of ParaView takes very long time on some Linux distributions. The analysis has shown that this problem takes place with some versions of gcc compiler. For example, this problem is reproduced on: - Mandriva 2010.0 64bits: gcc version 4.4.1. - CentOS 5.5 64bits: gcc version 4.4.0. The 'make' process freezes at compilation of ParaViewCore/ServerManager/SMApplication/vtkInitializationHelper.cxx file. The compilation, if not stopped, might take more than a week!!! :) In the end, the compilation of this file is successfully finished and rest of build procedure is done as usual. During the compilation of this file, CPU shows ~100% of loading (on multi-core systems only one core is loaded). The analysis has shown that the problem is caused by ParaView_build/ParaViewCore/ServerManager/SMApplication/vtkSMGeneratedModules.h file that is generated by kwProcessXML tool. Namely, this (very big) file operates with huge hard-coded string variables, e.g. ... // From file /data/mnt/vsr/tmp/ParaView-4.1.0_SRC/ParaViewCore/ServerManager/SMApplication/Resources/filters.xml static const char* const vtkSMDefaultModulesfiltersInterface0 = "<ServerManagerConfiguration>\n" " <ProxyGroup name=\"internal_filters\">\n" ... This problem can be fixed by patching of the Utilities/ProcessXML/ProcessXML.cxx file, in "void PrintHeader(const char* title, const char* file)" function, by replacing (in line 53) << "static const char* " << this->Prefix.c_str() << title << this->Suffix.c_str() << this->Count with << "static const char* const " << this->Prefix.c_str() << title << this->Suffix.c_str() << this->Count With this patch, the compilation of mentioned file takes just a second. No any negative side effect has been found after applying of this patch. | ||||||||
Project | ParaViS | ||||||||
Type | usability | ||||||||
(0033107) Tristan Coulange (developer) 2014-07-28 12:54 |
The change was approved on gerrit : http://review.source.kitware.com/#/t/4445/ [^] Fix slow compilation via processxml The compilation was very slow (days) with some linux and gcc versions: - Mandriva 2010.0 64bits: gcc version 4.4.1. - CentOS 5.5 64bits: gcc version 4.4.0. This change fixed the problem. See issue 0014821. Change-Id: I4b54f17140a56ae22b8e1af8532723e7c8a755b0 |
(0033165) Utkarsh Ayachit (administrator) 2014-07-31 09:00 |
SUMMARY --------------------------------------------- Topics merged into master: (VTK) 14599_fix_double_range_issues 14789_fix_border 14831_log_scaling_crash 14848_fix_mutlselection appdata-file catalyst-dependencies catalyst-kits compilation_issue_processxml excess-moc-wrapping fix-cache-doc fix-catalyst-python kit-libraries (VTK) newest-xdmf pass_connectid_to_autompi remove-mpi4py (VTK) update-vtk-20140729 --------------------------------------------- Topics reverted from next: 14813_fix_mode_shapes_range fix_proxy_widget_dialog_apply pvweb-fixes |
(0033261) Alan Scott (manager) 2014-08-19 18:13 |
Trusting that Vadim and Tristan tested. |
2014-06-24 11:25 | Vadim SANDLER | New Issue | |
2014-07-17 03:37 | Tristan Coulange | Assigned To | => Tristan Coulange |
2014-07-25 04:46 | Tristan Coulange | Status | backlog => active development |
2014-07-28 12:54 | Tristan Coulange | Note Added: 0033107 | |
2014-07-28 12:54 | Tristan Coulange | Status | active development => gatekeeper review |
2014-07-31 08:59 | Utkarsh Ayachit | Fixed in Version | => git-master |
2014-07-31 09:00 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-07-31 09:00 | Utkarsh Ayachit | Note Added: 0033165 | |
2014-08-19 18:13 | Alan Scott | Note Added: 0033261 | |
2014-08-19 18:13 | Alan Scott | Status | customer review => closed |
2014-08-19 18:13 | Alan Scott | Resolution | open => fixed |
2014-08-29 10:59 | Utkarsh Ayachit | Fixed in Version | git-master => 4.2 |
2015-01-11 08:16 | Tristan Coulange | Source_changeset_attached | => ParaView master 245c75c8 |
