0014843 | ParaView | (No Category) | public | 2014-07-08 11:25 | 2016-08-12 09:59 | ||||
Reporter | Dan Lipsa | ||||||||
Summary | 0014843: Slice interaction widget uses hardcoded colors instead of colors from the current ColorPalette | ||||||||
Description | Steps to reproduce: Add a Wavelet filter, Apply, add a Slice filter, Apply Edit, Settings, Color Palette, Select Palette to Load, Print, Apply, OK The normal to the slice plane and outline for the slice are white instead of using the foreground color (black). | ||||||||
Project | Sandia | ||||||||
(0036122) Alan Scott (manager) 2016-06-29 12:51 |
Also impacting box clip. |
(0038590) Kitware Robot (administrator) 2016-08-12 09:59 |
2014-07-08 11:25 | Dan Lipsa | New Issue | |
2016-06-29 12:51 | Alan Scott | Note Added: 0036122 | |
2016-06-29 12:51 | Alan Scott | Project | TBD => Sandia |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038590 | |
