0014857 | ParaView | (No Category) | public | 2014-07-11 09:24 | 2016-08-12 09:59 | ||||
Reporter | pierre piquette | ||||||||
Product Version | 4.1 | ||||||||
Summary | 0014857: Problem with compiling | ||||||||
Description | Hello, I have a probleme with the ParraView Compilation. When it arrive to the : "Linking CXX shared library ../../../lib/libvtkGUISupportQt-pv4.1.so" i have the error : CMakeFiles/vtkGUISupportQt.dir/vtkQtDebugLeaksModel.cxx.o: In function `int qRegisterMetaType<vtkObjectBase*>(char const*, vtkObjectBase**)': /applications/qt-4.8.2/include/QtCore/qmetatype.h:193: undefined reference to `QMetaType::registerTypedef(char const*, int)' CMakeFiles/vtkGUISupportQt.dir/vtkQtDebugLeaksModel.cxx.o: In function `QList<QString>::detach_helper_grow(int, int)': /applications/qt-4.8.2/include/QtCore/qlist.h:679: undefined reference to `QListData::detach_grow(int*, int)' CMakeFiles/vtkGUISupportQt.dir/vtkQtDebugLeaksModel.cxx.o: In function `QList<vtkObjectBase*>::detach_helper_grow(int, int)': /applications/qt-4.8.2/include/QtCore/qlist.h:679: undefined reference to `QListData::detach_grow(int*, int)' CMakeFiles/vtkGUISupportQt.dir/vtkQtDebugLeaksModel.cxx.o: In function `QList<VTKClassInfo>::detach_helper_grow(int, int)': /applications/qt-4.8.2/include/QtCore/qlist.h:679: undefined reference to `QListData::detach_grow(int*, int)' CMakeFiles/vtkGUISupportQt.dir/vtkQtDebugLeaksModel.cxx.o: In function `QList<QString>::detach_helper(int)': /applications/qt-4.8.2/include/QtCore/qlist.h:709: undefined reference to `QListData::detach(int)' CMakeFiles/vtkGUISupportQt.dir/vtkQtDebugLeaksModel.cxx.o: In function `QList<vtkObjectBase*>::detach_helper(int)': /applications/qt-4.8.2/include/QtCore/qlist.h:709: undefined reference to `QListData::detach(int)' CMakeFiles/vtkGUISupportQt.dir/vtkQtDebugLeaksModel.cxx.o: In function `QList<VTKClassInfo>::detach_helper(int)': /applications/qt-4.8.2/include/QtCore/qlist.h:709: undefined reference to `QListData::detach(int)' CMakeFiles/vtkGUISupportQt.dir/vtkQtDebugLeaksView.cxx.o: In function `QList<int>::detach_helper_grow(int, int)': /applications/qt-4.8.2/include/QtCore/qlist.h:679: undefined reference to `QListData::detach_grow(int*, int)' CMakeFiles/vtkGUISupportQt.dir/vtkQtTableModelAdapter.cxx.o: In function `QList<QModelIndex>::detach_helper(int)': /applications/qt-4.8.2/include/QtCore/qlist.h:709: undefined reference to `QListData::detach(int)' CMakeFiles/vtkGUISupportQt.dir/moc_QFilterTreeProxyModel.cxx.o:(.data.rel.ro._ZTV21QFilterTreeProxyModel[_ZTV21QFilterTreeProxyModel]+0xc0): undefined reference to `QAbstractProxyModel::setItemData(QModelIndex const&, QMap<int, QVariant> const&)' collect2: erreur: ld a retourné 1 code d'état d'exécution make[2]: *** [lib/libvtkGUISupportQt-pv4.1.so.1] Erreur 1 make[1]: *** [VTK/GUISupport/Qt/CMakeFiles/vtkGUISupportQt.dir/all] Erreur 2 make: *** [all] Erreur 2 Can anybody help me. Thank's | ||||||||
Project | Release | ||||||||
Type | usability | ||||||||
(0038596) Kitware Robot (administrator) 2016-08-12 09:59 |
2014-07-11 09:24 | pierre piquette | New Issue | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038596 | |
