0014858 | ParaView | (No Category) | public | 2014-07-11 20:39 | 2016-08-12 09:59 | ||||
Reporter | Andy Bauer | ||||||||
Priority | low | Severity | minor | Reproducibility | have not tried | ||||
Product Version | 4.1 | ||||||||
Summary | 0014858: saving an unstructured grid with polyhedra in it as a vtu in appended data mode does not work correctly | ||||||||
Description | Open the attached polyhedron.vtu and then save it as a .vtu file with default settings (Data Model set to appended seems to cause the problem). If you try to load that file into ParaView it can't. | ||||||||
Project | TBD | ||||||||
Attached Files | polyhedron.vtu [^] (2,567 bytes) 2014-07-11 20:39 | ||||||||
(0036060) Menno Deij (reporter) 2016-06-13 10:47 |
I think this was solved with https://gitlab.kitware.com/vtk/vtk/merge_requests/501 [^] I can't reproduce the problem with PV 5.0.1 |
(0038597) Kitware Robot (administrator) 2016-08-12 09:59 |
2014-07-11 20:39 | Andy Bauer | New Issue | |
2014-07-11 20:39 | Andy Bauer | Assigned To | => Utkarsh Ayachit |
2014-07-11 20:39 | Andy Bauer | File Added: polyhedron.vtu | |
2016-06-13 10:47 | Menno Deij | Note Added: 0036060 | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038597 | |
