0014884 | ParaView | (No Category) | public | 2014-07-24 10:01 | 2016-08-12 09:59 | ||||
Reporter | Andy Bauer | ||||||||
Summary | 0014884: ghost cells causing problems in pvti files | ||||||||
Description | Ghost cells are causing "cracks" between partitions of the original subdomains. Steps to reproduce: run the following script with pvbatch with 2 processes: from paraview.simple import * Wavelet() g = GradientOfUnstructuredDataSet() g.ScalarArray = ['POINTS', 'RTData'] w = XMLPImageDataWriter() w.FileName = "ghosts.pvti" w.UpdatePipeline() Load that into paraview and change to surface view. | ||||||||
Project | TBD | ||||||||
(0038606) Kitware Robot (administrator) 2016-08-12 09:59 |
2014-07-24 10:01 | Andy Bauer | New Issue | |
2014-07-24 10:01 | Andy Bauer | Assigned To | => Berk Geveci |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038606 | |
