0014893 | ParaView | (No Category) | public | 2014-07-28 07:30 | 2016-08-12 09:59 | ||||
Reporter | Vadim SANDLER | ||||||||
Assigned To | Tristan Coulange | ||||||||
Product Version | 4.1 | ||||||||
Summary | 0014893: Strange behavior when visualizing a field | ||||||||
Description | Load the binary file from the meppen4_proj_sb_bin.tgz archive First scenario: - Visualize the field ECRO. - Display the color legend and go to the end of the animation. => The visualization is correct. - Rescale to data range. => The visualization is incorrect, see attached wrong_prs.png Second scenario: - Visualize the field ECRO and go to the end of the animation. - Visualize the field CONT. - Visualize the field ECRO => The visualization is incorrect. About data to reproduce a problem: unfortunately files to reproduce a problem too big and I can’t attach files in the mantis. To obtain these files please send request to the bugmaster.salome@opencascade.com and I’ll send you link and password to the FTP server, or alternatively I can upload these files to the any provided server. | ||||||||
Project | ParaViS | ||||||||
Attached Files | wrong_prs.png [^] (16,002 bytes) 2014-07-28 07:30
(0033150) Tristan Coulange (developer) 2014-07-30 14:16 |
Hello, As I said for the issue 0014892, the problem comes from the binary file: it contains infinite values in the ECRO field, and ParaView does not support it. You can see that there are infinite values by looking at the ECRO ranges in ParaView (the step 43 for example, in the "Information" panel). So do you want us to develop support for infinite values? Or is it just a problem during the file generation? Tristan |
(0038609) Kitware Robot (administrator) 2016-08-12 09:59 |
2014-07-28 07:30 | Vadim SANDLER | New Issue | |
2014-07-28 07:30 | Vadim SANDLER | Assigned To | => Tristan Coulange |
2014-07-28 07:30 | Vadim SANDLER | File Added: wrong_prs.png | |
2014-07-30 14:16 | Tristan Coulange | Note Added: 0033150 | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038609 | |
