0014937 | ParaView | (No Category) | public | 2014-08-14 18:57 | 2016-08-12 09:59 | ||||
Summary | 0014937: Save Screenshot to PDF fails | ||||||||
Description | Whenever you try to save a screenshot to a pdf format, you get an error that simply says "Save Image failed." To replicate, simply select "File -> Save Screenshot", accept defaults for save options, and then save in PDF format. Unless this is super-easy to fix, I recommend simply removing the PDF option from save screenshot. If you want to save a PDF, using Export Scene is a much better option. | ||||||||
Project | TBD | ||||||||
(0034318) Alan Scott (manager) 2015-03-19 21:55 |
I just had a user ask for this feature. As per him, he would use it to create .pdf files for pdflatex. Please don't just delete this feature without asking. (User is Kevin M). |
(0038624) Kitware Robot (administrator) 2016-08-12 09:59 |
2014-08-14 18:57 | Ken Moreland | New Issue | |
2015-03-19 21:55 | Alan Scott | Note Added: 0034318 | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038624 | |
