0014938 | ParaView | (No Category) | public | 2014-08-15 11:02 | 2016-05-17 15:34 | ||||
Assigned To | Alan Scott | ||||||||
Summary | 0014938: Change Show Axis to Show Axes | ||||||||
Description | In the display panel there is a group called Cube Axis, which contains a checkbox labeled Show Axis. This latter label should be Show Axes. Axes, being the plural version of the word, is technically correct. Plus if you search for "axes" in the properties panel the option shows up whereas if you type "axis" nothing shows up. | ||||||||
Project | TBD | ||||||||
(0035968) Alan Scott (manager) 2016-05-17 15:34 |
Cube axes has been replaced with Axes Grid. Closing this bug report. |
2014-08-15 11:02 | Ken Moreland | New Issue | |
2016-05-17 15:34 | Alan Scott | Note Added: 0035968 | |
2016-05-17 15:34 | Alan Scott | Status | backlog => closed |
2016-05-17 15:34 | Alan Scott | Assigned To | => Alan Scott |
2016-05-17 15:34 | Alan Scott | Resolution | open => fixed |
