0014947 | ParaView | (No Category) | public | 2014-08-16 15:12 | 2016-08-12 09:59 | ||||
Summary | 0014947: Selections in line plots don't work properly when cell-based selections are made in render view | ||||||||
Description | + Wavelet, Apply + Plot Data, Apply + Show output of Plot Data in both the "Render View" and "Line Chart View". + Switch to show surface in Render View so you can make selections on it. If you select points in Render View, they show up properly in the Line Chart View. If you select cells, however, the Chart View doesn't show correct selection. | ||||||||
Project | ParaViS | ||||||||
(0033229) Utkarsh Ayachit (administrator) 2014-08-16 15:13 |
commit ad90b4d8519047d5da9068e4749f8547caaadaeb Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Sat Aug 16 15:02:46 2014 -0400 Added support for two selection transformation. When it comes to chart representations and selections, we need bi-directional transformation from view to input data and vice-versa. When a selection is created in the view, the application should get the selection that's defined on the elements in the input dataset (not the elements shown in the view). This is done using MapSelectionToInput() (formerly called TransformSelection) on vtkChartRepresentation. Then when a selection comes down the input pipelinen to vtkChartSelectionRepresentation, it needs to convert it to map to the elements in the view. This is done using the new vtkChartRepresentation::MapSelectionToView(). vtkChartSelectionRepresentation calls this in RequestData() before delivering the transformed selection to the rendering processes. With this changes, BUG 0014947 is addressed. Change-Id: Ia9a52cc011725b35a54a2ee695b8a3651fa31f67 |
(0033292) Utkarsh Ayachit (administrator) 2014-08-27 13:09 |
This has been fixed in git/master. |
(0033355) Alan Scott (manager) 2014-09-16 19:54 |
Tested Linux, master, 8 remote servers. Only worked if the selected cells were being processed on process 0. The other 7 processes wouldn't select correctly. |
(0033368) Utkarsh Ayachit (administrator) 2014-09-17 15:44 |
Developer notes: The problem is stemming from vtkSelectionDeliveryFilter. When this filter delivers the selection to the client. It ends up with multiple vtkSelectionNode instances, one for each rank. The chart views only work with the first selection node in vtkSelection and hence they ignore all other selection nodes. Thus only the root node's selection gets shown, others are ignored. |
(0038629) Kitware Robot (administrator) 2016-08-12 09:59 |
2014-08-16 15:12 | Utkarsh Ayachit | New Issue | |
2014-08-16 15:13 | Utkarsh Ayachit | Note Added: 0033229 | |
2014-08-16 21:57 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2014-08-16 21:57 | Utkarsh Ayachit | Status | backlog => active development |
2014-08-27 13:09 | Utkarsh Ayachit | Note Added: 0033292 | |
2014-08-27 13:09 | Utkarsh Ayachit | Status | active development => gatekeeper review |
2014-08-27 13:09 | Utkarsh Ayachit | Fixed in Version | => git-master |
2014-08-27 13:09 | Utkarsh Ayachit | Resolution | open => fixed |
2014-08-27 13:09 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-08-29 10:59 | Utkarsh Ayachit | Fixed in Version | git-master => 4.2 |
2014-09-16 19:54 | Alan Scott | Note Added: 0033355 | |
2014-09-17 08:53 | Utkarsh Ayachit | Status | customer review => backlog |
2014-09-17 08:53 | Utkarsh Ayachit | Resolution | fixed => reopened |
2014-09-17 15:44 | Utkarsh Ayachit | Note Added: 0033368 | |
2015-01-11 08:17 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 1162d307 |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038629 | |
2016-08-12 09:59 | Kitware Robot | Fixed in Version | 4.2 => |
2016-08-12 09:59 | Kitware Robot | Resolution | reopened => moved |
