0014951 | ParaView | (No Category) | public | 2014-08-18 17:22 | 2016-08-12 09:59 | ||||
Summary | 0014951: Values for decimation threshold in interactive rendering options makes no sense | ||||||||
Description | Under the Render View tab in settings, the values used for the slider under Interactive Rendering Options that controls the threshold for when to employ decimation make no sense. There are two really odd values being set: 1. The default threshold (until the user changes it) is 5MB. That is ridiculously small. I doubt there exist any ParaView users that need such a small threshold. This should be at least 50 or 100MB. 2. The max value is 100GB. That seem excessively high. The real problem is that having a slider going from 0 to 102400 means that each tiny movement of the slider is for a full gigabyte. That makes the slider totally useless. | ||||||||
Project | TBD | ||||||||
(0033263) Ken Moreland (manager) 2014-08-19 18:26 |
The max value for the remote rendering threshold is similarly high, causing the same problem with that slider. |
(0038632) Kitware Robot (administrator) 2016-08-12 09:59 |
2014-08-18 17:22 | Ken Moreland | New Issue | |
2014-08-19 18:26 | Ken Moreland | Note Added: 0033263 | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038632 | |
