0014952 | ParaView | (No Category) | public | 2014-08-18 18:43 | 2016-08-12 09:59 | ||||
Summary | 0014952: Typos in geometry decimation factor setting | ||||||||
Description | There are some typos for descriptions under Settings -> Render View. I will be updating this bug as I find more. "Set the factor used to compute the decimated geometry when employed. 0 implies minimal decimation (highest detail, hence more polygons that 1." -> I believe "that" should really be "than". Also, the end parenthesis is missing. "When opening a dataset or creating a new filters, use Outline representation, if possible, when showing datasets with number of cells greater than thus threshold (in millions)." -> "When opening a dataset or creating a new filter that has a number of cells greater than this threshold (in millions), use the Outline representation by default." The label "Set the compression method used when transferring rendered images from the server to the client." is erroneously shown twice. Once above the chooser box for None/Squirt/Zlib where it belongs and once above that on top of the "Image Compression" group label. The latter should be removed. | ||||||||
Project | TBD | ||||||||
(0038633) Kitware Robot (administrator) 2016-08-12 09:59 |
2014-08-18 18:43 | Ken Moreland | New Issue | |
2014-08-18 19:00 | Ken Moreland | Summary | Typo in geometry decimation factor setting => Typos in geometry decimation factor setting |
2014-08-18 19:00 | Ken Moreland | Description Updated | |
2014-08-18 19:07 | Ken Moreland | Description Updated | |
2014-08-19 16:27 | Ken Moreland | Description Updated | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038633 | |
