0014959 | ParaView | (No Category) | public | 2014-08-20 14:06 | 2016-08-12 09:59 | ||||
Reporter | Andy Bauer | ||||||||
Summary | 0014959: probe filter should return input grid cell data as cell data instead of adding it to point data | ||||||||
Description | the probe filter should set the cell data from its input to cell data on its output but instead sets it to point data. if there is a point data field with the same name it uses those values and doesn't give any information on the cell values at the specified location. also, this filter doesn't appear to work properly for cell data for multiblock data set inputs. | ||||||||
Project | TBD | ||||||||
(0038636) Kitware Robot (administrator) 2016-08-12 09:59 |
2014-08-20 14:06 | Andy Bauer | New Issue | |
2014-08-20 14:06 | Andy Bauer | Assigned To | => Utkarsh Ayachit |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038636 | |
