0014965 | ParaView | (No Category) | public | 2014-08-25 11:39 | 2016-08-12 09:59 | ||||
Summary | 0014965: Changes to solid color are not recorded in Python trace | ||||||||
Description | If you change the solid color of an object while Python trace recording is on, that coloring is not recored even if the trace was started with the "Fully trace supplement objects, such as color maps,..." checkbox is checked. To replicate, do the following. 1. Create a Sphere source. Apply. 2. Tools -> Start Trace 3. In the Trace Options dialog, check the "Fully trace supplemental objects..." checkbox. 4. Click "OK" 5. Click the Edit Colors button and change the color of the sphere. 6. Tools -> Stop Trace Note that the change in the sphere color is not captured in the Python trace. | ||||||||
Project | TBD | ||||||||
Relationships | ||||||
(0038639) Kitware Robot (administrator) 2016-08-12 09:59 |
2014-08-25 11:39 | Ken Moreland | New Issue | |
2014-08-25 11:49 | Ken Moreland | Relationship added | related to 0014966 |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038639 | |
