0014968 | ParaView | (No Category) | public | 2014-08-25 20:59 | 2015-07-08 22:07 | ||||
Assigned To | Alan Scott | ||||||||
Summary | 0014968: Sidesets - save data, Exodus is bad | ||||||||
Description | When you save data, possibly multiple input files, possibly sidesets, it is bad. This file will then crash ParaView upon read. Linux, master, local server. Open z_pinch1.exo.8.[0-7] dataset (8 exodus files). All variables on, all sets on. Apply. Ask Utkarsh or me for this dataset. Save data as exodus file. Save all timesteps. You get lots and lots of verbiage like this: arning: In /projects/viz/paraview/src/ParaView/4.2.0-alpha/ParaView4/VTK/IO/Exodus/vtkExodusIIWriter.cxx, line 952 vtkPExodusIIWriter (0x5d69400): Array in input field data has Null name, cannot output it Warning: In /projects/viz/paraview/src/ParaView/4.2.0-alpha/ParaView4/VTK/IO/Exodus/vtkExodusIIWriter.cxx, line 952 vtkPExodusIIWriter (0x5d69400): Array in input field data has Null name, cannot output it Warning: In /projects/viz/paraview/src/ParaView/4.2.0-alpha/ParaView4/VTK/IO/Exodus/vtkExodusIIWriter.cxx, line 952 vtkPExodusIIWriter (0x5d69400): Array in input field data has Null name, cannot output it Warning: In /projects/viz/paraview/src/ParaView/4.2.0-alpha/ParaView4/VTK/IO/Exodus/vtkExodusIIWriter.cxx, line 952 vtkPExodusIIWriter (0x5d69400): Array in input field data has Null name, cannot output it Warning: In /projects/viz/paraview/src/ParaView/4.2.0-alpha/ParaView4/VTK/IO/Exodus/vtkExodusIIWriter.cxx, line 952 vtkPExodusIIWriter (0x5d69400): Array in input field data has Null name, cannot output it Warning: In /projects/viz/paraview/src/ParaView/4.2.0-alpha/ParaView4/VTK/IO/Exodus/vtkExodusIIWriter.cxx, line 952 vtkPExodusIIWriter (0x5d69400): Array in input field data has Null name, cannot output it Warning: In /projects/viz/paraview/src/ParaView/4.2.0-alpha/ParaView4/VTK/IO/Exodus/vtkExodusIIWriter.cxx, line 952 vtkPExodusIIWriter (0x5d69400): Array in input field data has Null name, cannot output it Warning: In /projects/viz/paraview/src/ParaView/4.2.0-alpha/ParaView4/VTK/IO/Exodus/vtkExodusIIWriter.cxx, line 952 vtkPExodusIIWriter (0x96c82f0): Array in input field data has Null name, cannot output it If you read this dataset back in, it will crash ParaView. | ||||||||
Project | Sandia | ||||||||
Type | crash | ||||||||
Relationships | ||||||
(0034711) Alan Scott (manager) 2015-07-08 22:07 |
Duplicate |
2014-08-25 20:59 | Alan Scott | New Issue | |
2015-07-08 22:06 | Alan Scott | Relationship added | duplicate of 0015405 |
2015-07-08 22:07 | Alan Scott | Note Added: 0034711 | |
2015-07-08 22:07 | Alan Scott | Status | backlog => closed |
2015-07-08 22:07 | Alan Scott | Assigned To | => Alan Scott |
2015-07-08 22:07 | Alan Scott | Resolution | open => fixed |
