0014987 | ParaView | (No Category) | public | 2014-09-09 02:15 | 2016-08-12 09:59 | ||||
Reporter | Vadim SANDLER | ||||||||
Assigned To | Tristan Coulange | ||||||||
Product Version | 4.1 | ||||||||
Summary | 0014987: The presentation automatically updated in case visualization of the 2 fileds with the same names in the different views | ||||||||
Description | 1) Open attached files file1.vtm and file2.vtm (from the files.tar.gz archive) 2) Display and color first presentation by the "depl___DEPL" data array and "DX" component, show Color Map 3) Split view and create new Render View 4) Display and color second presentation by the "depl___DEPL" data array and "DY" component, in the second view, show Color Map 5) Activate the first view and select first presentation in the pipeline browser 6) Select the "DZ" as a Coloring component. => In the result a both view are updated, but expected updating only a first view. In case if fields have a different names, the automatic update of the second view is not done. The possibility to compare two components of the same field could be useful. | ||||||||
Project | ParaViS | ||||||||
Attached Files | files.tar.gz [^] (1,594,416 bytes) 2014-09-09 02:15 | ||||||||
(0033992) Utkarsh Ayachit (administrator) 2014-12-22 13:59 |
Vadim, Support this will be very tricky. It was part of the design for ParaView when we decided that all arrays with same name use the same lookup table. Our suggested path to do such comparative visualization as you want was to use filters like the "Calculator" to rename the array and then each one would get a different lookup table. We can add a new filter to make renaming of arrays easier and more intuitive, if that helps. |
(0038652) Kitware Robot (administrator) 2016-08-12 09:59 |
2014-09-09 02:15 | Vadim SANDLER | New Issue | |
2014-09-09 02:15 | Vadim SANDLER | Assigned To | => Tristan Coulange |
2014-09-09 02:15 | Vadim SANDLER | File Added: files.tar.gz | |
2014-12-17 07:12 | Tristan Coulange | Status | backlog => active development |
2014-12-22 13:59 | Utkarsh Ayachit | Note Added: 0033992 | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038652 | |
2016-08-12 09:59 | Kitware Robot | Status | active development => closed |
