0014991 | ParaView | (No Category) | public | 2014-09-10 21:51 | 2016-08-12 09:59 | ||||
Product Version | 4.1 | ||||||||
Summary | 0014991: 32 bit Windows remote server 64 bit data issue | ||||||||
Description | ParaView is failing successfully reading in 64 bit data, remote server, when the client is 32 bit. Strange, I know. 4.1.0, Windows 32, remote server. Load the attached file, which is vtu. Load all data. Apply. Split screen horizontal. Spreadsheet will be empty, and we get the following error: ERROR: In C:\DBD\pvs-x32\paraview\src\paraview\VTK\IO\Legacy\vtkDataReader.cxx, line 1919 vtkTableReader (15A2F090): Unsupported data type: | ||||||||
Project | Sandia | ||||||||
Attached Files | hawtWakeNode_10.vtu [^] (359,012 bytes) 2014-09-10 21:52 | ||||||||
(0038653) Kitware Robot (administrator) 2016-08-12 09:59 |
2014-09-10 21:51 | Alan Scott | New Issue | |
2014-09-10 21:52 | Alan Scott | File Added: hawtWakeNode_10.vtu | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038653 | |
