0015011 | ParaView | (No Category) | public | 2014-09-24 04:38 | 2016-08-12 09:59 | ||||
Reporter | Joachim Pouderoux | ||||||||
Product Version | 4.2 | ||||||||
Summary | 0015011: Slice representation generates lot of warnings in C/S mode | ||||||||
Description | When trying the slice representation (in a 3D view)on a 3D vtkImageData in PV 4.2, two problems were detected: - warning messages occures on both client and server side - in slice mode you can select the vtkProcessId field but it does not work and a warning message is displayed. It seems like in slice repr. the image is gathered and does not contain this field any more - nor the Normals field which is not supported by the Slice representation. The problem does not occur with PV 4.1. | ||||||||
Steps To Reproduce | - Start a parallel pvserver. - Start a ParaView client. - Connect the client to the server. - Create a Sources/Wavelet and Apply. - Choose the Slice representation and select the RTData array. - Change the slice position many times => warnings are displayed on server first, the on the client. - Change the array from RTData to vtkProcessId. This is allowed (whereas in PV4.1 only the RTData field is available in Slice mode) but a warning is displayed saying that the field is not found. | ||||||||
Project | TBD | ||||||||
Attached Files | bugSliceVue3D.png [^] (125,038 bytes) 2014-09-24 04:45
(0038662) Kitware Robot (administrator) 2016-08-12 09:59 |
2014-09-24 04:38 | Joachim Pouderoux | New Issue | |
2014-09-24 04:38 | Joachim Pouderoux | File Added: bugSliceVue3D.png | |
2014-09-24 04:41 | Joachim Pouderoux | Reproducibility | have not tried => always |
2014-09-24 04:41 | Joachim Pouderoux | Steps to Reproduce Updated | |
2014-09-24 04:44 | Joachim Pouderoux | File Deleted: bugSliceVue3D.png | |
2014-09-24 04:45 | Joachim Pouderoux | File Added: bugSliceVue3D.png | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038662 | |
