0015015 | ParaView | (No Category) | public | 2014-09-29 16:18 | 2016-08-12 09:59 | ||||
Reporter | Ben Boeckel (Kitware) | ||||||||
Summary | 0015015: Better defaults for format strings for data labels | ||||||||
Description | Currently, the default string for data labels is "%-#6.3g" which gives gibberish for non-floating point data values. We should have the default string change values based on the type of the input array (*any* user change should keep what the user wants though). Also deserves a "Reset" button to get whatever ParaView thinks the best format string should be. | ||||||||
Project | TBD | ||||||||
Type | usability | ||||||||
Attached Files | test.vtu [^] (1,132 bytes) 2014-09-29 16:18 | ||||||||
Relationships | |||||||||||
(0038664) Kitware Robot (administrator) 2016-08-12 09:59 |
2014-09-29 16:18 | Ben Boeckel (Kitware) | New Issue | |
2014-09-29 16:18 | Ben Boeckel (Kitware) | File Added: test.vtu | |
2014-09-29 16:26 | Ben Boeckel (Kitware) | Relationship added | related to 0015016 |
2014-10-06 05:57 | Joachim Pouderoux | Relationship added | parent of 0015023 |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038664 | |
