0015023 | ParaView | (No Category) | public | 2014-10-01 11:15 | 2016-08-12 09:59 | ||||
Reporter | capitalaslash | ||||||||
Product Version | 4.2 | ||||||||
Summary | 0015023: point IDs show up as reals instead of ints | ||||||||
Description | when showing point ids of a selection, the values are displayed as meaningless reals instead of ints. this used to work in previous versions. the spreadsheet view is unaffected. | ||||||||
Project | TBD | ||||||||
Attached Files | paraview_bug.png [^] (197,655 bytes) 2014-10-01 11:15
Relationships | ||||||
(0033593) Joachim Pouderoux (developer) 2014-10-06 05:58 |
This is due to a bad format string used to format IDs. Default is for floating point values. See bug 0015015. |
(0038669) Kitware Robot (administrator) 2016-08-12 09:59 |
2014-10-01 11:15 | capitalaslash | New Issue | |
2014-10-01 11:15 | capitalaslash | File Added: paraview_bug.png | |
2014-10-01 11:15 | capitalaslash | Description Updated | |
2014-10-06 05:57 | Joachim Pouderoux | Relationship added | child of 0015015 |
2014-10-06 05:58 | Joachim Pouderoux | Note Added: 0033593 | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038669 | |
